Aeg lavamat 73530 e50
E50
5 Suggested Answers
  • 326 Answers
SOURCE: I need cogs for my aeg lavamat where i CAN GET IT?
you can get it at  www.repairclinic.com
Posted on May 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: error E50 how can i
Hi
Thanks for using FixYa. Error E50 indicates motor fault, you’ll have to check the brushes and wiring of the motor and check if it makes a hum sound, if it does and you can see that the motor is not working then it is the motor that should be replaced. If everything else appears to be working fine then it is the PCB that should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 04, 2010
lidiya_k_99
SOURCE: AEG Lavamat 62800 keeps stopping
AEG Lavamat 62800 keeps stopping and displaying error E50. What is the problem and how do I fix it?
Posted on Apr 23, 2012
  • 884 Answers
SOURCE: What's your problem?AEG Lavamat 62800 keeps stopping and displaying error E50. What is the problem and how do I fix it?
Believe this is a motor fault. Change the brushes as a first fix attempt.
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
AEG Lavamat 60810 E50 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
E50 does mean problem with motor or tachometer placed on the motor. Could be: worn carbon brushes, motor faulty, wiring, electronic faulty.
E70 does mean problem with heating phase.
Could be: NTC sensor faulty or badly positioned, wiring faulty, electronic faulty.
Dado
AEG Lavamat 60810 E70 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
First of all, read exactly alarm code.
Press "Spin/Rinse hold" button and "Prewash" simultaneously for at least 2 seconds: the LED switch off and then display the
sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down. During the time the alarm is displayed, the appliance continues to perform the cycle or, if it is in the
selection phase, it keeps in memory the options previously chosen.
E70 - Family alarm code
  • E71 - Washing NTC sensor faulty
  • E74 - Washing NTC sensor badly positioned
Causes: NTC sensor badly positioned; NTC sensor faulty; wiring faulty; PCB faulty.
E50 - Family alarm code
  • E51 - Motor power supply triac short-circuited
  • E52 - No signal from motor tachometric generator
  • E53 - Motor triac sensing circuit faulty
  • E54 - Motor relay contacts sticking
Causes: Motor faulty; wiring faulty; PCB faulty; current leakage from motor or from wiring
Dado
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Aug 07, 2011 | Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
