Question about Garden
Ariens rm830 blade belt will not tension even when engaged
  • 10865 Answers
SOURCE: I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
Posted on May 20, 2009
  • 15 Answers
SOURCE: BLADE DRIVE BELT ADJUSTMENT
Well, most riding mowers have a "pully idler", meaning once you have the belt on there (and it is the RIGHT size), the idler automatically gives the belt tension when you engage it (in fact, the idler pully is what IS engaged when you engage the belly mower).
Couple things to check (super simple):
The Belt. Look to see if she is wore smooth out.
Sometimes....they WILL stretch on you, instead of busting/coming apart, and give you noise (when she is engaged, but wore out enough to flop around a little)
The Deck Blade Bearings. Straight away, that is what it sounds like, or bent blades.
Check your Blade Bearings (super simple):
1. Pick up your deck to the highest high setting (mower off, just sitting).
2. Reach under, and grab your mower blade (do this for both sides), and TILT your blade UP (meaning, don't LIFT the blade straight up).
Seriously, jiggle it at a TILT. If you feel some slack in the bearing, the bearing IS shot. Straight up and down is most of the time OK, IF it is VERY little play on your blade bearings. As you do it, look at your belt pulley directly on top, if you see that pully bobbing....
However, if you grab one side of the blade only, then tilt the blade up, and she moves.....
Bearings need replaced, both the upper AND lower bearings PER blade.
They are not hard to replace, and not expensive either! (Though unfortunately, most are "sealed" junk nowadays!)
Bad Bearings show up (make themselves known) in only a few ways: Tons of Noise (grinding, squealing) & Vibration.
Go check them thar Bearings!
Posted on May 28, 2009
Dolfoff
  • 148 Answers
SOURCE: Mower Belt Won't Engage
The fact is that belts don't stretch. They wear down on the sides, causing them to ride deeper in the pulleys and they APPEAR to be longer. Check belt "width" to see if it is less than one half inch. Most craftsman riders use half-inch (AKA: "A section") belts.
Posted on Sep 26, 2009
Testimonial: "I removed the mower & checked everything - pulleys, bearings, mandrells, springs. All OK. Re-assembled and it works again. Thanks for your feedback."
mowerman1857
  • 389 Answers
SOURCE: ariens 1440h cutting problem
moz-screenshot.jpgGo to this site: http://www.ariens.com/corporate/pages/partsradar.aspx (copy and paste in your address bar)
follow the instructions given and you can download a VERY GOOD picture of where it goes
Posted on Sep 29, 2009
extreme7528
  • 108 Answers
SOURCE: arien 34- Blades won't engage
This mower has an electric PTO on it. I had a Scag and the electric PTO clutch went out on it. Not the cheapest things to change but easy to do yourself with some basic tools. Also, before running out and getting a new one, check the wires to it and to the engage/disengage switch. You may have a bad connection.
Posted on Oct 12, 2009
Blades will not engage on Ariens A22A46
Some Ariens mowers have electric clutches. You can check for it and wiring to it. Maybe a wire is disconnected, wore thru etc. It sounds like it's not engaging.
Oct 14, 2016 | Ariens Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
Why can't I shift gears
that is because it is a posie trac rear end they all do that
Jan 21, 2018 | Ariens Garden
Why won't the blades engage on my Ariens 911403
Chances are the deck drive belt has been knocked off one of the pulleys or the drive clutch won't engage properly. With the spark plug wire removed, rotate the blades by hand and make sure they both move together. This verifies the blade linking belt is OK. Now engage the blade operating control and feel for resistance as you rotate the blades. If you feel no change in resistance, remove the belt cover and reinstall the drive belt over the pulleys and tensioner/clutch mechanism.
May 31, 2014 | Ariens 34 In. Zoom Series Riding Mower
PTO cable: Ariens 960160021
Sounds like you are missing a return spring. Your PTO if it's mechanical engage has a tension spring to bring it back when disengaged.
Apr 09, 2014 | Ariens Garden
Ariens Sport Zoom 1440 blades engage slowly
check that the grass has not bunched up around the spindle and shaft in such a fashion that it is jamming the blade to the deck and acting like a brake
Jun 06, 2013 | Garden
Belt systme view - how all belts are hooked up
you have 2 pulleys going to the blades, 1 pulley coming from the pto, and a belt tensioner. the belt goes on the outside of the pto, outside left side blade, inside belt tensioner, out side right side blade.
Aug 16, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
