Question about Garden
Ariens rm830e blade belt doesn't seem to tighten when engaged
  • 37 Answers
SOURCE: Ariens sierra 1440G belt configuration
Hi, you may have more than one problem. There should be one belt from the mower deck going to the electric clutch pulley which is on the engine shaft. On the shaft there are two pulleys, one belt comes from the mower deck, and the other comes from the transaxle pulley. check to see if your belts are in the right areas.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 27, 2008
  • 15 Answers
SOURCE: BLADE DRIVE BELT ADJUSTMENT
Well, most riding mowers have a "pully idler", meaning once you have the belt on there (and it is the RIGHT size), the idler automatically gives the belt tension when you engage it (in fact, the idler pully is what IS engaged when you engage the belly mower).
Couple things to check (super simple):
The Belt. Look to see if she is wore smooth out.
Sometimes....they WILL stretch on you, instead of busting/coming apart, and give you noise (when she is engaged, but wore out enough to flop around a little)
The Deck Blade Bearings. Straight away, that is what it sounds like, or bent blades.
Check your Blade Bearings (super simple):
1. Pick up your deck to the highest high setting (mower off, just sitting).
2. Reach under, and grab your mower blade (do this for both sides), and TILT your blade UP (meaning, don't LIFT the blade straight up).
Seriously, jiggle it at a TILT. If you feel some slack in the bearing, the bearing IS shot. Straight up and down is most of the time OK, IF it is VERY little play on your blade bearings. As you do it, look at your belt pulley directly on top, if you see that pully bobbing....
However, if you grab one side of the blade only, then tilt the blade up, and she moves.....
Bearings need replaced, both the upper AND lower bearings PER blade.
They are not hard to replace, and not expensive either! (Though unfortunately, most are "sealed" junk nowadays!)
Bad Bearings show up (make themselves known) in only a few ways: Tons of Noise (grinding, squealing) & Vibration.
Go check them thar Bearings!
Posted on May 28, 2009
SOURCE: I just installed mulch kit on my Ariens 34
i'm wanting to install a mulch kit too but it seems diffecult. hoew do you access under the mowing deck to install everything?
Posted on Sep 14, 2009
buffalonyman
  • 1865 Answers
SOURCE: ariens ezr1742 mower blades slow to engage and
Replace the belt
Posted on Sep 22, 2009
extreme7528
  • 108 Answers
SOURCE: arien 34- Blades won't engage
This mower has an electric PTO on it. I had a Scag and the electric PTO clutch went out on it. Not the cheapest things to change but easy to do yourself with some basic tools. Also, before running out and getting a new one, check the wires to it and to the engage/disengage switch. You may have a bad connection.
Posted on Oct 12, 2009
Have an Ariens Max Zoom 60, when engage the mowing deck the engine loads up and RPM's drops way down" Have tightened and loosened belt, what else can I Try?
Something in the mower blade drive is binding up. That puts a drag on the engine and causes the slow down in RPM.
Jun 16, 2017 | Ariens Garden
This id an Ariens 8 hp reasr engine rider
areins RM830e I found some info on Parts tree and Utube for you, take a look Ariens 927025 RM830E Ariens 30 Rear Engine Rider 8hp SN 000101 004000... . If not the right one repost and exclude this model .
Mar 16, 2016 | Ariens Garden
Why won't the blades engage on my Ariens 911403
Chances are the deck drive belt has been knocked off one of the pulleys or the drive clutch won't engage properly. With the spark plug wire removed, rotate the blades by hand and make sure they both move together. This verifies the blade linking belt is OK. Now engage the blade operating control and feel for resistance as you rotate the blades. If you feel no change in resistance, remove the belt cover and reinstall the drive belt over the pulleys and tensioner/clutch mechanism.
May 31, 2014 | Ariens 34 In. Zoom Series Riding Mower
Ariens Sport Zoom 1440 blades engage slowly
check that the grass has not bunched up around the spindle and shaft in such a fashion that it is jamming the blade to the deck and acting like a brake
Jun 06, 2013 | Garden
Can you tighten the belt that engages the blade?
check for a spring loaded idler pulley that keeps tension on the belt out of place.
May 17, 2013 | Toro Garden
Why won't my blades engage on my ariens zoom 1534?
take a look at the wires going to the clutch and make sure the wires where routed the right way and not rubbed against the belt and damage the wires
May 22, 2012 | Ariens 34 In. Zoom Series Riding Mower
Nov 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
