Question about Jl Audio E2150 Car Audio Amplifier
No sound coming out
My amp has power. the green power light is on, but there is no sound coming out of the speakers. the speakers are good. i hooked them up to the amp in my truck and they work great. i checked the outputs with a voltemeter with the stereo on, and i didn't get a reading. can anybody help?
  • 12,061 Answers
I often troubleshoot these issues via a stereo head set, modify the leads so you can "Touch" them onto the Speakers Output Terminals, connect the "Shields" together, thats "Earth" and the other Two, are Left & Right... with the Amp's volume turned to about 25% volume, connect up the Earth wires to the Chassis with a clip, under a srew etc, just make good contact... then touch the Left & right wires onto the output, ya should hear sound... if not most probably the Output device(s) may have gone faulty.
Posted on Aug 08, 2007
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
I have a sony explode1000 watt amp xm 2r1852 hooked up to 2 10" Sony explode 1100 watt speakers, my protection light comes on green and stays on but I don't have no sound .I've checked all the wiring and...
1000W system is enough power to blast your neighborhood. If the + and - connections are correct the speaker balance is connected properly. I assume you have checked the speakers and they have been working fine.
Thus, the problem is internal, within the amp. Make certain that you have selected the proper sound out to the speakers. With the speakers attached, keep switching around from one sound path to the other. Make certain, your source (input to the amp) is proper and the signal is communicating with the amp. If the amp has direct out ports to L/R Center and Surround that you can use wires to connect to the speakers, try that method.
Feb 17, 2018 | Car Audio & Video
Protection Light Comes on
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Mar 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplode 1000w amp has green light puts out no power to subs
may haveto turn sub on through the stereo itself if rca cables are good.
Jan 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
My amp is not working
For the visonik, you should check your speakers. You can use a D-cell battery. Remove the speaker wires from the amp and connect each speaker across the battery (for no longer than a few seconds). The speaker should pop each time the wires are touched to the battery. If they don't, the speaker is defective (assuming the battery isn't dead).
If the speakers are OK, you need to confirm that you have a good signal feeding the amp. You can use the RCA cables from another working amp in the vehicle. Do this with the amp that had the power light lit.
If you have signal going to the amp and the speakers are OK, the only two things left are the power supply feeding the amp (from the battery) and the amp. If you have B+ and remote voltage AND a good ground, the amp is defective.
For the pyramid, the amplifier probably has shorted output transistors. The amplifier will have to be repaired.
Nov 16, 2007 | Visonik V117SX Car Audio Amplifier
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
No sound comes out of speakers
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
May 22, 2007 | Dual XDM6825 CD/MP3/WMA Player
Kicker DX350
it sounds like you pop the power Reg. transistor or one of the Amp. chips instide. Some Amps has a pic fuse inside on the main board its green very small shape like a tear drop with a wire comeing out both ends it would in a socket some times white or black.
Sep 22, 2006 | Kicker DX350 Car Audio Amplifier
Jl Audio E2150 Car Audio Amplifier Logo
141 people viewed this question
Top Jl Audio Car Audio & Video Experts
matthew walsh
Level 1 Expert
Morne Olivier
Mike
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
