Question about Crate FlexWave FW120H Guitar Amp Head with DSP, 120W
Crate schematics - Crate FlexWave FW120H Guitar Amp Head with DSP, 120W
Schematic diagram for crate taxi50 amp
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 20, 2015 | Crate Music
Need G600 Schematic
Here is the link to Crate customer service-
http://www.crateamps.com/support/index.php
Feb 27, 2014 | Crate Music
Where is the serial number on a crate amplifier
Real basic owners manual is here:
http://www.crateamps.com/pdf/manuals/CA6110DG_OM.pdf
Look at the chassis, or pull a part number off the original speaker to match speaker and back cross reference to the amp versions that used it. The OM is at least good enough with the block diagram to allow it to be serviced easily enough.
Feb 21, 2012 | Crate CA6110DG Gunnison Acoustic Guitar...
I need schematics for this amp. know where I can get them?
Josh,
I also need schematics for this amp. How about whoever finds it first shares with the other?
Cool, Thanks,
bob at stumpweb.com
Jan 27, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN SHUT OFF. NEED SCHEMATIC AND ADVICE TO ISOLATE THE BAD CAP IN WHICH CIRCUIT THAT IT IS OSCILLATING.
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Sep 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate GTX-30 Guitar Amp Schematic... The thing blew, and I need to replace two components...
Hi. use this link to check for the schematics.
crateamps.com/support/discontinued.php
or
music-electronics-forum.com/sitemap/f-60.html.
take care.
May 31, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Bass amp blowing fuses
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
Jun 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Apr 18, 2009 | Crate Music
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, techmail@loudtechinc.com.
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate FlexWave FW120H Guitar Amp Head with DSP, 120W Logo
20 people viewed this question
Top Crate Music Experts
rjivaro
Ben Armstrong
richie46
Are you a Crate Music Expert? Answer questions, earn points and help others
