Question about Range Rover Evoque Pure & Prestige Rear Mud Flaps 2012
Dtc fault code p006c-92 - Range Rover Evoque Pure & Prestige Rear Mud Flaps 2012
2000 Pontiac Montana 3400 3.4 V-6. The security system is engaged showing low fuel but its full, the 10min. reset didn't work. What is a hard fault? Please help..
You need to have a scan tool hooked up to read DTC'S diagnostic trouble codes ! These would be hard faults .
DTC 6 Theft Deterrent Relay Control Circuit Shorted
DTC B2734 Coded Key Controller Memory Failure
DTC B2960 Invalid Coded Key Present
DTC B3031 Key Decoder Device in Assem Learn Mode
DTC B3055 Key Not Present.
Do you have another key you can try .
Oct 27, 2016 | Pontiac Cars & Trucks
Bought car at auction- no keys. Had key made at GM dealer. Programmed key- key works. Car wont start- Codes are P0633 and P1629. cannot clear codes
DTC P0633 : Theft Deterrent Key Not Programmed
When learning the pre-release password, as well as the challenge and response sequence, the engine control module (ECM) is placed in learn mode. DTC P0633 will set automatically as an indicator that the system is in learn mode and not as a fault indicator. Once the password and challenge/response are learned, learn mode will be exited when the engine is successfully started. At this point, the DTC will be cleared. If the ECM does not exit learn mode, P0633 will remain current and indicate a fault.
The "key" referenced in the DTC descriptor does not refer to the vehicle key. In this case, "key" is referring to the challenge response.
DTC P0633 requires a successful engine start to exit the learn procedure and clear the DTC. If an unrelated malfunction exists that causes engine starting to be disabled or otherwise unavailable, learn mode will not exit and DTC P0633 will remain current. In this situation, the cause of the inoperative engine starting must be corrected before diagnosing DTC P0633.
DTC P1629: Theft Deterrent Fuel Enable Signal Not Received
The theft deterrent module (TDM) sends the pre-release password to the engine control module (ECM) via the serial data circuit. The ECM then sends a challenge to the TDM. Both the ECM and TDM perform a calculation on this challenge. If the calculated response from the TDM equals the calculation performed by the ECM, the ECM will allow vehicle starting.
DTC P1629 is an indicator that the challenge response was not received within the required 2 second window. This does not necessarily indicate a fault is present with the TDM or ECM. Factors such as a long engine crank, a delay in the serial data communication, or B-codes set in the TDM will cause DTC P1629 to set. This DTC should not be used as a fault indicator, but rather as a symptom to assist in the diagnosis of these other systems.
Who checked the codes , you -dealer ? You need to have BCM checked for codes B - codes ! you need a up scale diagnostic scan tool for that , dealer Tech -2 !
DTC B3935 57 : Transponder Authentication Error
DTC B3976 46 : Unconfigured Transponder/Vehicle Configuration Not Programmed
DTC B3060 : Unprogrammed Transponder Identification Code Received
DTC B3055: No Transponder Modulation or No Transponder
DTC B3031: Security System Controller In Learn Mode
Aug 07, 2015 | 2006 Buick Lucerne
I have a 2002 Jaguar X-type. The check engine light came on and it has been acting jumpy/shaky. I recently took it to be diagnosed and the codes I recieved back were P1314, P1316, P1111, and P0302..What do...
All fault codes can be checked out at http://www.bluejag.co.uk but here are the results for some of yours. You can ignor P1111. Looks like a faulty plug or coil pack cylinder 2
Fault Code:- P1314 Indicates a Power-train fault
The fault is generally due to a problem in the Ignition or Misfire area
Fault Description: Misfire rate catalyst damage -bank 2 NOTE: This DTC will flag only when accompanied by an individual cylinder misfire DTC: P0300 - P0306
Action of ECM:- ECM Default:- Maximum engine speed reduced
After clearing the DTC, complete the Misfire monitor drive cycle
Check for a reoccurrence of fault DTC.
Possible Fault:- Cylinder compression low Worn camshaft / broken valve spring(s) Fuel delivery pressure (low / high) Fuel injector(s) restricted / leaking Fuel injector(s) continuously open Fuel contamination Fuel injector circuit fault(s) (Injector DTCs also flagged) Spark plug failure / fouled / incorrect gap ECM to ignition coil primary circuit fault (Cylinder misfire detected DTC also flagged) Ignition coil failure
Fault Code:- P1316 Indicates a Power-train fault
Fault Description: Misfire excess emission NOTE: This DTC will flag only when accompanied by an individual cylinder misfire DTC: P0300 - P0306
Action of ECM:- none
Fault Code:-
P0302 Indicates a Power-train fault
Fault Description: Misfire detected ?€" cylinder 2
Possible Fault:- Refer to P0300 Possible Causes
Aug 25, 2011 | 2002 Jaguar X-Type
Code po560
You will find all Diagnostic Code details available at http://ww.bluejag.co.uk .
This code P0560
Fault Code:- P0560 Indicates a Power-train fault
The fault is generally due to a problem in the Vehicle Speed & Idle Control area
Fault Description: Battery power supply voltage malfunction Note: This DTC can be flagged due to fuel injection pressure sensor fault. If P0193 is also flagged, correct first.
After clearing the DTC, complete the Engine temperature cool (cooling fans not running) Remove ignition key for 20 seconds (cooling fans not running) Ignition key in, position II for 5 seconds (do not start) Repeat cycle two additional times
Possible Fault:- ECM battery power supply open circuit, high resistance
Jun 18, 2011 | 2002 Jaguar X-Type
My s type jaguar dtc p1638 i dont undarstand the mining of that why, 2000 year it asking me to look in the manual tecnical book
Fault codes are listed in the technical handbook, no good to you as it's a Jaguar service item unless you can get a copy of JTIS from ebay etc.
Fault Code:- P1638 Indicates a Power-train fault
The fault is generally due to a problem in the Computer & Output Circuit area
Fault Description: CAN ECM / INST network malfunction
After clearing the DTC, complete the Ignition ON 10 seconds
Possible Fault:- CAN open circuit fault - INST to ECM CAN short circuit fault INST failure ECM failure D
May 26, 2011 | 2003 Jaguar X-Type
I have a 1997 Chevy Blazer with the 4.3 engine. The Service Engine light keeps coming on. I scanned the codes and replaced the O2 sensor just before the catalytic converter. The light is still coming on...
P0146 pd means pending code
Pending codes and DTCs? Posted on November 12, 2010 by fcrmaster
When reading codes from your vehicle the fault code reader may show them as pending codes or normal Diagnostic Trouble Codes (DTC).
Pending codes (also known as continuous monitor codes) will be registered when an intermittent fault occurs. If that fault does not happen again after x number of start/stop cycles, the ECU will erase the code from memory. If the fault is persistent it becomes a DTC.
If you have read pending codes it is advisable to check the codes again after a week or so. If there is no apparent problem with the vehicle it is safe to erase the codes too and check back. But always make a note of any fault codes with the date and mileage of a vehicle.
If the codes read include a DTC then you need to investigate further. This you can either do yourself or advise your garage. If, again, you don't see an apparent problem (depending n the severity of the code) with the vehicle you can note the codes down and erase them. Then check again after a week or a few days depending on how often the vehicle gets used. If a repair has been made (previous owner) the DTC may just not have been reset after the repair.
The other numbers behind the code 01/06 , 02/06, 03/06 , 05/06 ,04/06 These don't mean anything . cheap code reader .
DTC P0140 HO2S Circuit Insufficient Activity Sensor 2
DTC P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3
DTC P0171 Fuel Trim System Lean Bank 1
DTC P0174 Fuel Trim System Lean Bank 2
Sorry but this is something you should take to a qualified repair shop that has a diagnostic tool that can view sensor scan data.
Causes of lean condition trouble codes P0171 P0174 GM 5 3L
Jul 23, 2017 | 1999 Chevrolet Camaro
My ST 92 Salva Oven displays fault code AL 3 what does it mean
my salva st-92 oven is displaying AL9 fault code
May 05, 2010 | Ovens
1996 jaguar xj6 dtc test code p1178
Fault code P1178Rich Fuelling Trim, Long Term (AMFR)Check for manifold air leaks, rectify as necessary Check for recorded MAFS fault code, rectify as necessary Clear fault code and perform service drive cycle to verify fault cleared Contact Jaguar Service Hotline if fault still present.
Taken from the Jag service manual.
Feb 26, 2010 | 1995 Jaguar XJ6
Air Conditioner for Benz 1998 E320
Check system for codes;
Displaying & Reading Trouble Codes (DTC Memory)
Air Conditioning (A/C)
Models 208 as of MY 1998
Diagnostic trouble Code Memory [15]
Note:
  • The A/C pushbutton control module (N22) has DTC memory and data output. The diagnostic trouble codes and data are displayed via the temperature display window. The stored DTC's will remain in memory even with the vehicle battery disconnected.
  • The DTC memory differentiates between current and intermittent faults.
  • Numerous DTC's can also be read with the Hand-Held Tester (HHT).
Preparations for DTC Readout
  1. Review 11, 12, 13, 14, 15, 21, 22, 31, 31, 41
  2. Ignition: ON
  3. Temperature selector: left: "HI"; right: "LO"
  4. Ignition: OFF
  5. Ignition: ON
  6. Within 20 seconds press REST and EC simultaneously for more than 5 seconds.
  7. The LED in Recirculated Air flashes and the display shows "d1A".
  8. Press AUTO repeatedly until all DTC's are displayed. Record each DTC as it is displayed.
  9. Each fault (short circuit, open circuit) is assigned a DTC. Thus in the left display: "E1" appears, and the right display indicates the DTC. The current faults (refer to table) are displayed first, next, the intermittant failures (e.g. 45 °5) are displayed in the display window next to the FAN symbol. By pressing the right AUTO the next DTC is displayed.
  10. To erase: Can only be performed after all faults have been readout. Press left AUTO and right AUTO buttons simultaneously for more than 2 seconds and the display shows: left: "d" and right: "FF". To cancel erase: By pressing the left AUTO button, the current faults will appear again.
  11. Select a base temperature setting.
  12. Turn ignition OFF, to end test.
Note: Due to instrument cluster (IC) series interface, DTC's may be stored in IC memory, therefore readout and erase DTC's from IC memory.
133090425133090426
Aug 20, 2008 | 1998 Mercedes-Benz E-Class
Range Rover Evoque Pure & Prestige Rear Mud Flaps 2012 Logo
43 people viewed this question
Top Range Rover Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Range Rover Air Tool and Compressor Expert? Answer questions, earn points and help others
