Question about Garden
Bad boy kill switches
I can jump start my Bad boy and it will run fine, but I can not get it to start with the key. The battery is good. To jump start it I have to connect the cables directly to the starter and by-pass the battery. There must be a kill switch that is not working properly that won't let the starter engage. I don't know where it is???? Anyone know??
SOURCE: Won't crank--some kind of electrical problem
Disconnect the (battery) starter cable and check with a multimeter the continuity of the starter relay thru the relay terminals which connect the battery to the starter (key will have to be turned to start) -- if you get continuity, it's likely not the relay, but I'm with you, it sure sounds like the relay (solenoid).
P.S. Running a starter directly off a charger is a good way to burn up a charger.
Posted on Apr 28, 2009
  • 59 Answers
SOURCE: mower won't start
sounds like the ground cable is bad
Posted on Jun 26, 2009
  • 22 Answers
SOURCE: 2000 yamaha vstar 1100 custom. starter problem?
I had the same problem 2001 XVS1100 Custom
this is a starter issue Over time the starter on this bike twists when its under a load.
Look at the two bolts holding the starter on if they are not straight across then its twisted. turn starter back in line with a pair of big channel locks and try to start this should do the trick if this works i would recommend taking the two bolts out and bend them back straight or replace and reinstall starter this should fixya problem
Hope this helps ...............Jimmyfixya
Posted on Jul 08, 2009
  • 173 Answers
SOURCE: My Cub Cadet model 1525 rider won't start. I turn
You could have a seat safety switch bad. Bounce up and down on the set to work the safety switch often.
  • 62 Answers
SOURCE: cub cadet 2166 won't start. replaced switch.
SOUND LIKE A LOW VOLTAGE PROBLEM. MAKE SURE YOUR BATTERY IS GOOD
Posted on Sep 25, 2009
What could cause atv 110 engine to not turn over at all? Battery is good, seems as if kill switch is engaged.
check for a fuse that's going to be close to the starter solenoid. next take a piece of metal like an old screw driver and jump the 2 posts on the solenoid to see if it cranks. if nothing happens your either going to have a bad connection or a bad starter. if it does crank then I would look at your start switch or ignition switch. just start chasing wires and making sure there all good, theres nothing fun abut chasing electrical problems so take your time and crack a beer.
Aug 07, 2014 | Roketa 110cc Middle Size ATVs
08 Chevy Cobalt wont start. Battery is good.?
Generally speaking, if the starter was dead it would not jump start.
Sounds like the key switch or the neutral safety switch.
You would need to know if the starter has power when the key is in the start position.
Feb 15, 2014 | Cars & Trucks
Suzuki Vitara no power to starter, every thing else electrical works.
2000 VIT (which engine, 1.6L 2.0L?) what transmission, A/T or M/T
auto or stick?
chip, what chip.>??? there is no starter chip
the NO Crank this is called.
did use jumper cable jump , off a running good car? yet.
this is the #1 first check.
(starter motor work now? yes, bad battery or simply discharged)
jumper starts, dead? that means we need to do test 2.
we hot wire the starter, motor solenoid.
jump tiny wire to big lug there.
it cranks fast, (wont start, keys are in pocket for safety) yes? good
no crank hot wired is a bad starter or seized engine. (turn engine by hand?)
yes, cranks hot wired.
that means the KEY line is dead. (bad PRNDL or bad Clutch switch)
if input to above switch is bad the ignition key switch is bad.
some VIt have an immoblizer. so the light for it must not glow. if opted.
see the tricks section !!!
the below shows all possible test. and all ways to fail and how to find it.
http://www.fixkick.com/nocrank.html
Jan 28, 2014 | 2000 Suzuki Vitara
My 2005 suzuki aeiro wont start.battery is good . wont turn over
what transmission,?
this can be 3 things, if it wont jump and batter is good.
bad connections at battery or starter.
1: bad starter.
2: bad (A/T shift switch) or bad M/T clutch switch.
3 bad ignition switch.
4: bad wire or connections end to and start system.
hot wire the starter solenoid, if car starts (cranks) then its 2 o 3.
Apr 07, 2013 | Suzuki Cars & Trucks
Killed then we jumped started it it went about 2 miles and killed again. we jump started it again,got it running as soon as we took the jumper cables off the running car it killed
if you have a bad altinator it will drain your battery causing the enguine to stop running. and if you killed the car that was jumping it then i def would get the altinator tested on both cars as jumping a car with a bad altinator can cause charging issues on the car doing the jumping.
Jan 29, 2011 | 1997 Pontiac Sunfire
My van will not start, it was working fine, its not the battery or oil or coolant . A mechanic who looked at it said maybe there is a start kill switch or fail safe switch or something like that. I...
There is a "Kill switch" that shuts off the fuel pump whenever a crash is detected. It should be located where this is at in the owner's manual ... When you say "Kind of Loose" are we talking "I can rattle the key a bit" or "I can pull the key out with the ignition in the 'run' position" ?
Jan 17, 2011 | 1994 Mercury Villager
I see on here where u have answered questions about ppl trying to start their durango and just get a clocking noise. Ok so here goes....my car for a while because my battery was almost dead and then dies...
If you have a new battery and it keeps going dead, then either you have a bad battery or the alternator is not charging properly. Altenator not charging could be either a bad alternator, loose belt, or bad wiring coming from alternator.
Dec 23, 2010 | Dodge Durango Cars & Trucks
My daughters blazer was running fine last night. She went out to go to work today and when she turned the key. It just clicked and clicked. I am going to jump start it when she gets home. If that...
use decent jump leads ,if it starts then take a battery terminal off and if it keeps running renew the battery if it stops renew the alternator
Aug 18, 2010 | 1999 Chevrolet Blazer
My 2002 lancer battery keeps dieng but starts whem i jump it but when i kill it tha battery dies any answer what the problem is
If the car runs everytime you jump it & continues to run until you shut the engine down & won't restart, then it is either a bad battery, or bad connections from the battery to the starter solenoid & fuse box. If the ground connection were bad your car wouldn't start when jumped & it's apparent that once you get enough voltage(jumping it) to the cars starting system it will run, there are no other options. Battery or wiring.
Good luck
Jan 27, 2010 | 2002 Mitsubishi Lancer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
