Question about Rucanor Exercise & Fitness
Green Pedometer Have no manual,does this one need a battery? If so where I do not see any opening. It does not work except for the panic alarm.
3 Suggested Answers
SOURCE: How do you set the gaiam pedometer alarm?
yes - after setting time for alarm, press mode and set to get alarm icon on screen
Posted on Jun 05, 2009
6ylucy
  • 742 Answers
SOURCE: Missing a battery for a Sportline Model 342 Pedometer.
You should be able to get every Sportline Pedometer manual here
Posted on Aug 27, 2012
Panic alarm does not work. Locksmith verified that it is not the remote fobs.
central timer module" - Dodge Dakota Forum
www.dodgedakota.net/boards/gen/21983.html
Jan 2, 2009 - 21 posts - ‎18 authors
I have a Dak 2000 3.9 Ltr V6, Single Cab, Bare Bones. ... Panic Mode .... ooops....i mean the remote entry and alarm system does NOT work ... i have a 2002 dakata where can i buy a ctm looked all over nobody sell them can thay be rebuilt ... I was out the door $550.00, and they washed the truck also.
Truck wont work/Key Fob won't work/wont start/wont do anything ...
www.ramforumz.com > ... > Electrical
Apr 10, 2010 - 10 posts
Truck wont work/Key Fob won't work/wont start/wont do anything! ... Maintenance & Repair > 3RD Generation Dodge Ram - 2002 to 2008 Dodge Ram Trucks > Electrical... Soon as I manually unlock the door, and open it.... the factory panic alarm starts going off. .... Vehicle: 2004 Dakota Club Cab 4X4.
alarm going off when opening the door.. embarrassing and annoying ...
www.cumminsforum.com > ... > 3rd Gen. Non-Powertrain
Jan 12, 2012 - 11 posts - ‎9 authors
how do I stop my trucks alarm from going off when I open the door? it did it ... to thetruck and opened driver door (it was unlocked) and the alarm started going off. ... I do not have a remote unlocking device (or it doesnt work) so I do all .... alarm will go off then I have to use the FOB panic button to shut it off.
Keyless entry/panic button/alarm - Dakota Durango Forum
www.dakota-durango.com > ... > Gen III Dakotas
Jan 10, 2016 | 2002 Dodge Dakota Club Cab
Why would the anti-theft alarm go off?
Factory alarms rarely false alert, maybe someone did tamper with the car and ran off before you saw him. The one thing that will often trip alarms is a bad battery in the car, have it tested. Your car may have an add-on alarm in which case anything goofy can happen. It's odd that you had to hit the panic button to shut the alarm off, but if it functions normally otherwise it's unlikely to need a new battery. Is it at all possible that you hit the panic button and that caused the alarm to sound? If it was in your purse or pocket maybe it got pressed in which case it might be normal for you to have to hit panic again to turn it off.
Apr 07, 2015 | Lexus Cars & Trucks
I can't turn it on
Mine wouldn't turn on either....what they do not tell you is that inside, (take out for four screws and open the meter), is another battery under a silver round clip. Take that bettery out and replace it....works like a champ now!.
Sep 01, 2012 | Gaiam Walking Fit Kit Pedometer...
My Tanita 3 Axes Pedometer Pd724 got wet n the alarm started to go off . I had to take the battery out to stop and every time I put the battery In the alarm starts again and I cannot do anything else help...
Hi honeyrauniar
The alarm goes off when the pedometer is pulled away from the pin (at one end) to which the strap is attached. Just push the pin back in and it stops the alarm!
RM
Dec 08, 2010 | Tanita 3 AXES PEDOMETER (PD724)
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    TDS 3-button keyless remote operating instructions please
    RED opens the drivers door, BLACK opens all the doors, and GREEN turns on the head lights
    Apr 30, 2010 | 1998 Toyota Camry
    The remote on my 2008 Jeep Commander is totally fickle. Sometimes it works, most of the time it does not. I open it with the manual key and the panic alarm goes off. When I put the remote key into the...
    try replacing remote batteries, but must have a second programmed key to reset first one in case its gets uncoded, best advise do not take long time to replace battery, if problem persist have a good honest mechanic inspect door key cylinder security switch if it is not disconnected, but before you do this, if right side front door or rear door has cylinder try opening vehicle from this doors, if they unlock vehicle and alarm doesn't go off you might have problems inside driver's door cylinder switch, on this year vehicle must use STAR SCANNER from chrysler jeep dodge to solve problems
    Nov 19, 2009 | 2008 Jeep Commander
    Same problem here. If your pedometer is rectangular, with slanted window, LR 44 battery should work.
    Oct 23, 2009 | Sportline Exercise & Fitness
    Jun 04, 2009 | Gaiam Walking Fit Kit Pedometer...
    Exercise & Fitness Logo
    55 people viewed this question
    Top Rucanor Exercise & Fitness Experts
    Electro Med Services...
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you a Rucanor Exercise and Fitnes Expert? Answer questions, earn points and help others
