Question about Pool & Spa
Trevi spa i have a flo error after cleanning my spa
2 Suggested Answers
SOURCE: 2001 arctic spa is showing error code FLO
FLO is for not enough water flow
This is a filter issue or pump issue. Remove filters and see if it goes away. If it does get some new filters here: http://www.hottubworks.com/
If it does not go away call us and we will walk you through trouble shooting. Most likely a circ pump if not filters.
Posted on Oct 26, 2012
Leisure Bay -My spa will not heat - no FLC/FLO code/Voltage is correct/4KW Dry Element Heater test 15.9 Ohm across leads and OL on each to housing
It appears per your test that the heater May not be the problem as it shows that it may be good.
Your error message is a Flow condition / Restriction
Try cleaning the filter
Nov 09, 2014 | Pool & Spa
Lo flo pool power rp23
Clean your filter,...
... just a slight sensing of "Lower" water flow, may trigger the sensor to read not enough water flow. Also check your impeller, your skimmer baskets & the hair and lint pot basket at the pump.
If all those are confirmed as clean & clear - then you may have a faulty flow sensor.
Apr 24, 2014 | Pool & Spa
How do I reset error code on imperial hottub..?
Flo code is not a resettable message. That means you have a problem. Is it flashing (interactive with temp) or is it solid (only the Flo Code) ?
Both of these are two different problems, and they have to be corrected before the message will clear.
Try cleaning the filter, or if it is older than 18 months, replace it.
Nov 21, 2013 | Imperial 7 Person Hot Tub Spa
Circulation pump is running but FLO is displayed on panel and heat light goes out.
FLO is displayed because something has caused a reduction in water pressure through the heater. The spa control will turn the heater off when FLO is displayed to prevent a burn out.
I suggest checking the filter cartridge, the suction fittings & any valve which could be partially closed & restricting flow.
Try run the spa with out the filter cartridge if this clears the error then it is the cartridge.
If none of these work it is possible the your flow switch and/or pump is beginning to fail.
Mar 24, 2013 | RTO Sundance Heater Element Harness Black...
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Parts
That would likely be FLO... Check to be sure you have good strong water flo at the jets returning to the pool or spa... Check your filter to be sure you have cleaned it properly. A dirty filter will reduce flo and result in the heater not working if the water flow is too low.
There unfortunately a large number of factors to be able to provide much more information without a detailed description of your equipment, the layout, valve positions and condition of the equipment.
Aug 12, 2012 | Jandy Pool & Spa
Flo code is on and pump won't start up
Flo = Improper flow or pressure switch malfunction or Flow switch malfunction (system specific).
Before you purchase a new pressure switch:
- Clean or replace your filter cartridge (if its older than 1 yr).
- Check that all slice/gate valves are up/open.
- Check water lines for blockages incl. suction cover & ensure sufficient water level in spa.
Jan 29, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a 2003 Arctic spa and have changed the heater. I have a HL sensor error on the panel but the tub is cold?
HL usually means that the heater is working and there is no water passing through it, do you get a flo error message before the HL,I had the same problem, mine was the flo switch
Oct 08, 2010 | Pool & Spa
I have an XP2 in my 6 year old above ground spa. Recently the breaker keeps flipping after about 15 minutes of use and the pump motor is very warm. Is the pump done??
You have a gage on your filter? Anywhere on your system? I would suspect yout system should run at about 18 to 28 lbs PSIG when clean and go up about 10 lbs PSIG when it needs to be back washed.
Aug 19, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
