Canon CLC 1180 Copier Logo
Posted on Mar 14, 2009
Canon CLC 1150
The maschine warm up 1-2 Minutes,
after then the Maschine says Error E008 0000, and the
maschine switched off.
What can I do?
Thank you for helping!
Tom
color_50
Level 1:
  • Contributor 22 Answers
  • Posted on Mar 14, 2009
color_50
Contributor
Level 1:
Answers
22
Questions
Helped
9522
Points
49
Check the Delivery Door Switch SW5/ Also check AC Relay near power cord Assmbly=check contacts clean if dirty
2answers
Service manual
Code error E 020, 0173
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Flooding problem in a AWM8146
Sounds like pressure switch or feed hose to the switch blocked or faulty
2answers
E0000 0132 error on Canon CLC 1150
this is the fixing error indication reset it * 2 & 8 simultaneously * Copier>Function> Clear>Err>OK .Restart the Machine
Canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
1helpful
2answers
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
E005 0100 Error
asfter clearing the error code turn the machine off then on again, if that dosen work remove the web then clear cut off turn on
2answers
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
old marine
old marine
ZJ Limited
ZJ Limited
