Question about Hotpoint 24 in. HDA3740G Built-in Dishwasher
HOTPOINT dishwasher flooding my kitchen floor
My dishwasher, model no. HDA3740G02SA, decided to freak out on me tonight and flood my kitchen floor. I've never had this problem before, but the machine has always made weird noises when washing..sort of like a grinding sound? I've just recently moved into this apartment, the guy who I moved in with moved out...so I don't know if there where any issues with the washer before. I also don't know anything about these machines, but I do know that I now have stagnant water in the bottom of the washer, most of which I scooped out, but I not able to figure out if the thing is clogged or not. Can someone help?
  • Said Parker Aug 07, 2007
    no, it doesn't.
  • gerryd2 Sep 07, 2008
    dishwasher makes noise, and water was left in the bottom. checked to see if food was blocking . none. bailed the water out.
  • 641 Answers
Does water comes into the dishwasher all time, even when it doesn't operated?
Posted on Aug 07, 2007
  • Dov Dror Aug 07, 2007
    In this case,it sound like a water level switch problem (doesn't show the "full" water position). The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube.
    In case it doesn't react, you should replace it.
    Good luck !
Did you use a detergent not intended for automatic dishwashers, i.e. dawn liquid etc.? If you do, it will over-suds on you and the suds will pour out of the machine in the middle of the wash cycle.
I know, because it just happened to us...! My wife bought some "eco-friendly" soap and the genius at the store said it was safe for automatic washers...but it is not (clearly states so on the bottle, and we didn't notice that until after the kitchen floor was half covered in bubbles...)
Hope this helps someone, its an easy thing to rule out/fix at the very least...
Posted on Sep 03, 2008
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Drainage pump appears blocked. All filters and pipes are clear. Where &how do I acess the pump
you will have to provide the make and the model number of the dishwasher. Generally the pumps are at the base. You will have to disconnect the unit and drag it out on the floor. The access to the pump can be obtained by laying the dishwasher on the side. make sure there are few towels around to avoid flooding the kitchen floor.
Nov 05, 2012 | Dishwashers
Hotpoint dishwasher 4th & 6th lights flashing
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
Dishwasher not emptying after a wash cycle... water flooding kitchen floor.. help!
there is a switch on the floor of the dishwasher, might be dome shaped,lift up on this and see if it is stuck or clogged with gunk
Nov 10, 2010 | KitchenAid Dishwashers
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Dishwasher
if you say it washes it may be confused with the drain pump running all the time
if this the case the machine may have a flood switch in base of machine this means that the machine has flooded or has a leak so you need to pull machine out take outsied and check for leaks
Feb 24, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Hotpoint 24 in. HDA3740G Built-in Dishwasher Logo
1,652 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
