Question about Samsung RF217ACBP
Evap fans work but do not come on
It is a twin with 2 evaps and neither is coming on, I tested both motors with a 12 volt battery and motors work, what would cause them not to come on and what would cause them to come on?
Sea Breeze
  • 4655 Answers
SOURCE: Refrig evap fan not running, but fan OK
You can remove the fan and apply the normal voltage for your home or use a test meter to check the wires going to the fan. It should be the house voltage. Let me know, Sea Breeze
Posted on May 29, 2009
rockitman187
  • 2559 Answers
SOURCE: both freezer and frig fan are not working.
The fan control board is bad and needs replacing.
Posted on Jul 30, 2010
Testimonial: "thanx for solution finally got part ordered few weeks ago box is working fine now"
  • 2006 Answers
SOURCE: freezer side of my RS2534WW
Your indications does not make sense! Your unit has ONE compressor that uses ONE evaporator coil to cool both sides. So if the FREEZER side is not cooling the fridge side should not cool either! Are you sure you don't have the freezer and refrigerator sides reversed?
Posted on Aug 14, 2011
heatman101
  • 43501 Answers
SOURCE: evap fan noiisy and compressor runs constantly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 09, 2011
  • 884 Answers
SOURCE: Samsung side by side twin cool Refrigerator side not cooling
Is it freezing from the bottom up? If so check the drain is clear. If it's freezing all over, check the condenser is clean and clear and the compressor switches off when it reaches temperature. Lastly, check the door seals properly all the way round
Posted on Apr 23, 2012
Cart wont move just hums was working ? 85 Ezgo 36 volt
If all wiring is factory then check batteries under load. If all good then test motor. With rear wheels off the ground, disconnect the main pos and neg wires from the batteries. Then disconnect the four wires from the motor. You can use a voltmeter to measure the value of the two coils of the motor. Measure between A1 and A2 then S1 and S2 ( sometimes F1 and F2) Should get 1 or 2 ohms. If that good then jumper A1 to F1, connect A2 to 12 volts and F2 to 12 volts, one neg and the other pos. You will get a spark but the motor should start turning if good.
Jul 26, 2017 | Golf
Kenmore 106.54584400 fridge warm, air baffle No open in normal ops. in test mode opens and closes but evap fan does not run. fan motor runs during normal ops. thermistors good in test mode.
I would meter test the evap fan it may have gone out cuz if it was ur defrost timer or cold control you would have no motor condenser fan working either? and no cold control damper working in test mode?
is the fan impeeded or just not moving?
May 21, 2015 | Kenmore Refrigerators
Bownes lawn tractor wont turn over. Battery fully charged and all safety switches were changed. its a briggs and stratton 12 1/2 horsepower
with a volt meter set to DC, pull the wires off of the starter solenoid coil (the small wires) and check for 8 - 12 volts DC at the wires when the key is turned. A poor connection at the solenoid coil will cause slow turning engine cranking or none at all.
If you have 8 - 12 volts there check for voltage to ground on the large cable that goes from the solenoid to the starter motor, one probe on the cable and the other on ground or ( - ) at the battery. Turn the key to start, if you have voltage to the starter motor but it does not turn loosen and retighten the mounting bolts to the starter motor and if that does not help do the same for the engine to ensure you have a good ground. If none of that works your starter motor needs to be replaced, if you have no voltage to the motor the solenoid or battery connections are faulty.
You can also quickly test starter health by conecting a set of jumper cables to a good battery, clamp the neg. to the engine block anywhere and tap the pos. to the starter cable connection from the starter solenoid, if the engine spins over your starter is healthy and the issue is certainly between the key switch and the starter solenoid.
Jul 07, 2014 | Briggs & Stratton Briggs Stratton Intek V...
I've bought (at auction) a Marketeer 36 volt electric truck (similar to what you see pulling luggage carts at airports). Before spending money to buy 6 new 6 volt batteries, I'd like to know whether the...
I doubt your understanding of how the motor works is correct. More likely 2 of the terminals on the motor are for the field coils. The battery charger should not be used directly to power the motor without a battery also connected. The motor would function as a short circuit to the battery charger.
Instead, you can use 2 car batteries to test if the motor works. The full 36 volts is not needed.
Sep 16, 2013 | Dryers
1995 Isuzu Rodeo won't start all of a sudden.
Check connection battery,could be starter.
Jun 05, 2013 | Cars & Trucks
Ezip 500 won't run : new batteries fully charged but it still shows low battery light...what else could be wrong
i'm having the same problem. checked fuses and both are good. going through the wiring harness to look for shorts. have a bad feeling the micro controller died, that is the little plastic box with metal fins on it under the seat post behind the batteries ******* to the frame. i can bypass the micro-controller and connect one 12 volt battery directly to motor and runs full speed. somehow it is wired with 2 - 12 volt batteries in series to give 24 volts and them the processor cuts back down to 12 volts to run the motor. not sure why this is engineered this way? still working the problem. what sucks so far is that the micro controller is encased in resin so it is virtually non repairable.
* Update added.
Found these wiring harness for sale online scooter stores and on ebay. I replaced mine with some intermediate level adapting the harness to my model scooter and this includes some soldering and wire splicing changing power connector heads off old harnedd to new harness to fit bike. Works great.
Jan 02, 2013 | UPG New Replacement Batteries 4 EZIP E Zip...
How can i know if my voltage regulator is working, Im not getting any of my lights to work
quick check is to remove a battery cable while the motor's running. If the motor stays running when you pull off the battery cable, the charging system is functioning properly, if it dies then there is a problem with the charging system. Don't leave it off long, as this test is stressful to the circuit. You can test the voltage regulator by putting a volt meter across the battery posts to verify voltage. A fully charged 12 Volt battery should show slightly above 12 volts DC. With the engine running and the volt meter hooked to the battery, the charging system should be showing around 13.8 volts DC.
Dec 02, 2012 | Cars & Trucks
I want to test motors on pergo gator can i hook up reg 12 volt lawn battery to test that they spin or can i test charger
no don't hook it up to regualr 12 volt battery, first check the voltage of the peg perego battery and make sure that its putting out 12 volts, then you can use jumper wires and connect to the motors with the peg perego battery and verify that they work
Jun 25, 2011 | Peg Perego John Deere Gator HPX Ride on...
Voltage to evap fan 94v not working runs slow @ 120v
Hi, I deal with evaporator motors on a day to day basis.If the motor is running but not up to full speed, the inner windings of the motor are going out. If the motor runs as you say, is it getting only 94 volts to it? If this is the case, check the incoming voltage to the unit itself. Check to see on the schematics what is between the motor where you may be loosing your voltage. Defrost thermostat, or timer. Check power to the timer first and get back to me. The defrost thermostat supplies power to the fan when the evaporator temperature gets cold enough and the contacts will close and send power to one side of the motor. If it is going bad, it will cause you to loose part or all of the voltage. If you have a meter, check this. It is round and sealed with 2 terminals on it. If it is cold enough, you can check the leads to ground and see if you are getting less then 120 volts coming out the motor side. If so, replace the thermostat. Please keep me posted.
Sincerely,
Shastalaker7
PS Be safe around electricity. Also, this defrost stat snaps around a evap. line.
Dec 28, 2009 | Amana Refrigerators
Wiring problem may be a broken neutral between compressor and evap fan inside freezer, Compressor and comp fan motor runs noting else inside works.
chk for voltage at evap motor in freezer,more than likely evap motors bad they also can have fan on shaft come loose ans jamb up motor and this will also result in a burned out motor
Aug 17, 2009 | Refrigerators
Samsung RF217ACBP Logo
56 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
