Question about Philips 51PP9910 51" Rear Projection HDTV
Bent picture The picture on my tv screen looks like it is bent. The info bar at the top of it has a rainbow shape but not a rainbow color effect. The words that are displayed on the sceen look doubled. I tried to use the manual converge menu but none of that seemed to help. Help please
  • jasrox Jul 12, 2008
    My tv also looks doubled and I also tried to fix with the red blue and yellow but it didn't work. It looked like the main plus sign was the one that was curved I got it to where I can see the tv ok on regular channels ( I mean you can still see it curve, but it looks a little better) although on HD channels there is no way of fixing it you see red and double all kinds of stuff.
  • 398 Answers
The convergence circuits straighten out the edges of the picture, putting the 3 colors exactly where they should be for the picture to look normal. There are usually 2 large IC's that handle the 6 convergence channels and if one of them burns out then one of the colors bends dramatically. If the power supply for the convergence circuits stops working, then all 3 colors bend in, the colors do not line up with each other and the image looks almost 3D, and the adjustments in the convergence menu will have no effect. I would bet that is the case with your set - the convergence power supply has quit working. If you do not have experience troubleshooting power supplies and realigning convergence circuits in projection TV's then allow a qualified tech to handle it for you.
Posted on Aug 07, 2007
Ok thanx for telling me why the problem occurred =) ..now how do u fix it???
Posted on Jul 10, 2008
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid changBent picture - 65af323.jpg/>65af323.jpg
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 15, 2009
2 Suggested Answers
SOURCE:
SOURCE: Bent picture
Not sure if you fixed your problem already. But the answer is a color convergence problem. You can try adjusting manually via the remote and if that doesn't work it is most likely the two main IC chips that control the color convergeance. It is also possible that not only the IC chips have gone bad but also there are a couple of resistors that usually burn out with the ICs as well. They will need to be replaced. This isn't something that I would attempt on your own. Typically a TV technician will charge between 300 and 400 to fix at your house.
Posted on Apr 20, 2008
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
The top and bottom of the picture makes a rainbow effect toward each other in the center of the screen++++++++TV. model 3 ws55807 it's a 55 inch screen the problem occurs all the time. I have no TV repair...
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than this tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fix the tv convergence board to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Mitsubishi WS-65807 65" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Screen appears to be bent at the top and bottom.
Ur convergence it dead.U know how to solders?Buy a convergence kit use what in that kit.Tries these Websites for parts.Tv repair World.com,Tvrepairkits. Tv shop will cost u $300.Repair by tv tech.
Dec 16, 2009 | Philips 60P8341 60" Rear Projection...
Picture is bent. color is a bit fuzzy and 3 lines
Ur convergence it dead,know how to solder?Buy a convergence kit use what in that kit.Tries websites Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA HD52W59 HDTV Projection Television
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Bent picture
Mar 15, 2008 | Philips 60PP9363 60" Rear Projection...
Moved the tv and now have a line on bar in top half with bend to it?
sounds like solder on convergence amps has hairline crack's
needs resoldering...
Oct 19, 2007 | Toshiba 51H84 51" Rear Projection...
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Philips 51PP9910 51" Rear Projection HDTV Logo
2,084 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
