Question about iRobot 5800 Scooba Vacuum
Scooba 5800 Power button Red Blinking (Continued)
Hi, I did check the voltage measurements as shown on my attached picture. I did check the power supply into the Scooba is 22V as the manual said. Step 1: it shows the battery is low (3V). Step 2: it shows the Temp. senor line is 5 V and already pumps into the battey, +/- ve terminals are almost 0V (not activated yet) Step 3: it shows the Temp. senor line dropped to 2.5V (means with load). the +/- ve terminals has slightly higher voltage that the battery. I don't know the charging voltage pattern of Scooba. (Supposes 14.4 V?) Even the Power button Blinking Red, I have monitored it for 12 hours and found the voltage of the battery is keeping growing up 10.00 V as it is only 3V at the beginning. Any advises on battery or Scooba, which one has problem? Any suggestions appreciated Thank you very much
  • Edmund Yuen Aug 07, 2007
  • Edmund Yuen Aug 11, 2007
    Hi KOakaKO,
    Thanks you for your advice
    I will do the first step to replace the old battery by a new one before doing further studies on that. I will target to a higher failure rate device (battery).
    Thanks a lot
    Best Regards,
    Edmund
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
As for which one has the problem, I would say it has to be the battery. Rechargeable batteries of all types are known to have similar characteristics, one of which is discharging the batteries to maintain good rechargeablility. At least one person has demonstrated this for the Scooba battery in the roombareview.com forums when he brought a "dead" battery back to life. He allowed the battery to slowly and completely discharge using a 12-volt automobile bulb, followed by recharging the battery on the Scooba external charger. This procedure brought his "dead" battery back to a full charge! However, other forum members have reported that many have experienced problems with Scooba battery life, and that as a consequence of this iRobot will replace your battery if you call them and report a short-life battery problem. You can contact iRobot at (800) 727-9077 if you would like to report a battery problem and request a replacement.
Posted on Aug 11, 2007
  • Kevin Omel
    Kevin Omel Aug 11, 2007
    After reading further, it appears that the number to call for warranty, repair or service information is: 877-855-8593
SOURCE:
IRobot Scooba 5800 "check tank" light
Why buy something used that is not in perfect operating condition? There may be other problems yet to be discovered.
Dec 31, 2013 | iRobot 5800 Scooba Vacuum
Scooba 5800 starts to charge then beeps loudly
1) test the batteries very well in another device.
2) test the charges if working properly.
3) test the power inside from scuba, some electronic components like diode, or capacitor is draining the batteries. repair or rreplace.
God bless you
Sep 19, 2012 | iRobot 5800 Scooba Vacuum
Have Scooba 340 that won't power on after battery fully charged!
No repair services anywhere, unfortunately. It does sound like you might need a new battery, but the issue could also be the power button. I suggest giving us a call at 1-877-855-8593 so that we can more accurately determine what the problem might be and how we can most efficiently help you to solve it.
Fembot
iRobot Tech Support
Aug 15, 2009 | iRobot 5800 Scooba Vacuum
My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Jul 26, 2009 | iRobot 5800 Scooba Vacuum
Irobot scooba 5800 spins quickly then sets off backwards
Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
May 10, 2009 | iRobot 5800 Scooba Vacuum
Scooba won't turn on
It sounds like you've got a finicky power button. Not a lot that can be done about that, but you may want to try getting your hands on the old-style Roomba remote, the black one. The power button from that will power on a Scooba, though you can't start a cleaning cycle that way. This might allow you to bypass the Scooba's power button altogether.
May 08, 2009 | iRobot 5800 Scooba Vacuum
Scooba in diagnostic mode
This is a common issue :)
his morning, I turned on my Scooba and it started beeping a scale of tones and blinking all its lights in sequence. After an hour or so of resetting, cleaning, disassembling, researching, and scratching my head, I stumbled across the solution on Roomba Review. But, for me at least, it was even easier than all of that. I don't have any of my own pictures for this procedure, but it's pretty straight forward.
  • Remove the battery and power.
  • Remove the two screws holding the bumper shell in place and remove it.
  • Carefully peel up the sticker with the control buttons on it. This sticker is actually the control panel. There is a data cable attached to it just below the "Clean" button. Be careful not to break it!
  • Clean the surface under the sticker with some isopropyl alcohol. (I didn't actually have to do this, but I'm sure it doesn't hurt.)
  • Gently replace the "sticker" (i.e. control panel) and make sure it's completely flat.
  • Check to see if it works again. If not, repeat.
  • Replace the bumper shell and screws....
thnx.
Jan 23, 2009 | iRobot 5800 Scooba Vacuum
Service code 1
a red 1 is a pump malfuntion
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
Scooba circles and only goes backwards.
try cleaning the cliff sensors under bumper
Dec 13, 2008 | iRobot 5800 Scooba Vacuum
You probably have the manual, but here's the link to the Scooba 5800 manual anyway - just in case this would be useful to you: --> http://www.irobot.com/images/homesupport/5800_Scooba_Manual.pdf You could use a voltmeter to check the battery, but only a few months use shouldn't be enough to wear it out. If you don't have a load-tester to verify the battery's load-capacity, then you can check the voltage drop. (Assuming you can get it to contact the Scooba's circuits.) To do this, just check the battery voltage, apply a load by inserting it in the machine and turning it on, then check the battery voltage again. An excessive drop in voltage may indicate the battery needs replacing. However, the red blinking light is Scooba's indicator that it doesn't detect the battery at all. The first thing to do in this case is to clean the electrical contacts on the battery and in the Scooba. Use a damp cloth and a bit of toothpaste to rub the contacts clean on the battery and in the machine. (Toothpaste has mild abrasives in it and will clean the electric contacts without damaging them.) Make sure that both the battery and the Scooba are clean and dry before re-inserting the battery. Also, if the electric contacts in the machine are flexible matal tabs then verify that the tabs are standing up high enough to make good contact with the battery contacts. Hopefully the battery just needs it's contacts cleaned for your unit to work, but test the battery if you are sure that they are clean and seated properly to the contacts in the machine. If the battery appears to be failing, then contact www.irobot.com to cheack and see if they are still covered under your machine's warranty. Hope this helps! :)
Aug 06, 2007 | iRobot 5800 Scooba Vacuum
iRobot 5800 Scooba Vacuum Logo
965 people viewed this question
Top iRobot Vacuums Experts
Oliver Street
Level 1 Expert
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
