Question about Kenmore 73189 Air Conditioner
Kenmore Model #731893 Room Air Conditioner
Turned of AC this morning everything was fine. Got home in afternoon, pressed power button, nothing. No lights, no sound nothing. Checked breaker, checked plug, everthing looks ok. Help.
  • Rhonda Fatchett Aug 28, 2007
    Sorry,
    Thanks for your help. Could not get back to you, was out of town. Bought a new one.
  • GCJustUs Oct 16, 2008
    I have the same problem. Did youever find the problem?
  • 725 Answers
Does you air conditioner have a GFCI on the end of the plug if it does there is a reset there.. let me know if it doesn't and you want to go deeper?
Posted on Aug 24, 2007
My kenmore 12000 btu portable air conditioner keeps switching to DH mode out of AC mode
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
http://www.sears.com/kenmore-portable-room-air-conditioner/p-04272012000P
Jul 05, 2015 | Kenmore Portable Air Conditioner 10000 BTU...
Air fan turns on for few sec. then off
Good Afternoon Jonathan, thanks for your post!
From the information you have provided the fan on your Frigidaire air conditioner turns off after a few seconds of being on. This could be an issue with your fan motor or control panel. I would suggest performing a reset on your air conditioner. You can do that by unplugging the power cord and pressing the rest button. You should then hear a click and press the test button then plug the air conditioner back in. If that does not correct your issue you may need to have a technician out to your home to perform a proper diagnosis and repair. I hope this information is helpful to you. -Matt
May 28, 2015 | Frigidaire FFRA0811Q1 8,000 BTU Window...
Ac unit keeps tripping the reset button
Good Afternoon Friend,
I understand your Frigidaire air conditioner, model# LRA074AT7, which keeps tripping the reset button. I see that it will start up and then trips the reset button after a minute or two. First, be sure the electrical service is adequate for the model you have chosen. This information can be found on the serial plate, which is located on the side of the cabinet and behind the grille. Secondly, be sure the air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Lastly, your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire 6500-BTU Window Room Air...
Air conditioner won't turn on. I turned it off
Check the thermostat to make sure it is set for cooling and calling for Ac. Check outside to make sure fuse for disconnect if any is blown .if everything check out then open cover and check contactor .If contactor is pulled in and nothing run check capicator .
Mar 05, 2018 | Heating & Cooling
Good evening all, This morning woke up to my home
Sounds like a faulty Tstat that's sending a low voltage signal to the contactor coil only sometimes. The high pressure cut out or the compressor's internal thermal protection could of opened, and then closed again after cooling. Make sure the condenser is clean and not obstructed.
Aug 31, 2013 | Whirlwind FH-778 Air Conditioner
Please HELP Single MOM fix A/C
It could be several things, Not like changing a light bulb. If the fan's shot the unit will try to cycle, will stop, will click, will sit a little and everything starts over again...That's just one item...the easy one..
Because of it's age and other problems, I strongly suggest Goodwill, St. Vincent's. Home Depot right now, has a 5kw (small room 10x15 max.) for a hundred bucks.
The old unit is bagged...time to go!
Jul 17, 2013 | Kenmore Portable Room Air Conditioner
I have a window air conditioner in my living room. It runs constantly because my asthma acts up when it's too hot or muggy outside. When I went to bed last night, I had the AC on low. When I got up this...
Might just be a broken wire. OR it could be a failed cap. 9fc3991.jpge93a4cc.jpgIf all of that is good and you have power to the unit then either the control or the thermister is shot.
ITTY ***** AC SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 21, 2010 | Kenmore 6000 BTU Single Room Air...
My air conditioner will not turn on. (See below for a more detailed description.) I recently bought a used Kenmore Room Air Conditioner Model 580. 76129. It worked well for about a month (running almost...
AC has a relay, it sounds like it failed on ya. If the unit was on all the time, was it that hot where you were or do you mean switched from AC to fan on all day? From what you said, it sounds like the unit burned its relay out for overheating, meaning thermostat may have originally failed keeping unit on until relay popped. Careful of fire hazard.
Jul 07, 2010 | Kenmore 76129 Air Conditioner
Will not blow air of any kind...nothing
pls try to turn the fan with your hand if no noise( with power off) then change the capacitor
Apr 27, 2009 | Heating & Cooling
Maytag AC afternoon out to lunch
Clean the condenser coil and change the filter.
May 09, 2008 | Maytag Chassis Built-In Air Conditioner...
Kenmore 73189 Air Conditioner Logo
408 people viewed this question
Top Kenmore Heating & Cooling Experts
1STHVACMAN
Bill Long
Jay Finke
Jay Finke
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
