Question about Saeco Starbucks Sirena Espresso Machine
The temperature gauge on my Saeco Sirena espresso machine is not working but the water still heats up and there is still pressure.
4 Suggested Answers
  • 11 Answers
SOURCE: Saeco Sirena Espresso Machine...how can I get to
Sounds like you need to descale your machine
Read the manual under descaling
Here is a link to the manual
Posted on Aug 03, 2009
SOURCE: Unable to prime Sirena Espresso Machine
n regards of the no prime issue. this is the only way i could prime this new puppy.make sure its stone cold which is a no brainer since it will not heat h2o unless its primed. first take off steamer plastic tip ,turn on steamer clock wise till pump starts. then **** the tip of the end of the metal tip hard until pump stops may need to do it a couple of times. yes this seems out of this world but it works. you are flushing out the vapor lock in the pump. bravo enjoy!
Posted on Nov 29, 2009
EsWorld
  • 1618 Answers
SOURCE: Machine will not heat up
Sounds like the thermostat tripped, check the top of the boiler and reset.
Posted on Sep 19, 2010
Where is the water intake hose on Starbucks Sirena espresso machine
I think those are made to fill but do not have a water hose. See the manual here.
https://www.cerinicoffee.com/content/Manuals/Saeco/Sirena_manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Aug 08, 2016 | Saeco Starbucks Sirena Espresso Machine
Sirena Espresso Machine powers on but will not heat up and water not priming
After weeks of trial and error, I have found the solution, to prime the Starbucks Sirena Saeco Espresso Machine (woohoo!!!!!!!!!! ). You do not need to disassemble this machine, it will not heat unless it is prim WARNING: machine must be STONE COLD before attempting this! 1. Get a large syringe (Without a needle of course, I used a 60ml one I bought at a pharmacy for $3.) 2. Fill the water tank full 3. Pull off chrome tip on the steam wand to expose the black plastic jet where steam comes out. 4. Place the tip of the syringe onto the tip of the black plastic steam jet on the machine. 5. Push the power button ON. 6. Turn the steam knob clockwise all the way until the pump starts. 7. Press the syringe onto the jet firmly to seal the connection, and simultaneously draw the plunger out. 8. Quickly, release the seal and eject the air in the syringe out (into open air not into the machine) 9. Repeat steps 7&8 until water draws into the syringe. 10. Go make yourself a cup of coffee and celebrate that you overcame the flaw in this machines design that renders most of them to the rubbish heap.
Jul 12, 2015 | Saeco Starbucks Sirena Espresso Machine
I have a 14 month old Sirena expresso machine. It
Check the thermostat or element on the top of the machine.
Mar 16, 2010 | Saeco Starbucks Sirena Espresso Machine
How long should it take for the water to get hot, on a first time use?
Mine takes about 30-60 seconds to heat to brewing temperature. About 10 seconds more for steam.
Nov 22, 2009 | Saeco Starbucks Sirena Espresso Machine
Starbucks sirena won't heat up; blue light flashing-brand new
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Sep 27, 2009 | Saeco Starbucks Sirena Espresso Machine
Starbucks sirena lights won't turn on
Just had this happen. Finally I let water run through the steam wand (thought it had to heat up first). Water ran through (until blue light stopped blinking) and now the other lights are blinking...we will see if it works now.
Sep 05, 2009 | Saeco Starbucks Sirena Espresso Machine
Sirena espresso machine leaks water from under the tank slowly. I can't seem to find the source of the leak but I didn't take the machine apart either.
It's the hose from the steam boiler to the upper boiler. Part number 16000190 Silicone Tube 4,2X8,2. It is the same tubing as you would find on a fish tank with a red woven cover - I guess to prevent leaks. I cut out a short section that had developed a hole because it is not designed for the heat and pressure, but it shortly started to leak again. The tubing is not the correct kind for this purpose.
Now i am trying to find where to get a replacement tube without having to send it off someplace.
Aug 16, 2009 | Saeco Starbucks Sirena Espresso Machine
Sirena won't turn on - yes it is plugged in.
I have had the same problem, it was caused by poor connection at the power cord (machine end). The contacts inside the cord end are poor. I swapped out the original cord for one I had kicking around (from old computer monitor), and the machine came back to life. Just make sure the wire gauge is the same as original (18 AWG).
Good luck
Mar 15, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Starbucks Sirena Espresso Machine Logo
67 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
