Question about Garden
Alpina strimmers vip 25
Does the head unscrew clockwise or anti clockwise to adjust cord
2 Suggested Answers
  • 316 Answers
SOURCE: head removal
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, 22
Posted on Feb 19, 2012
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
Strimmer spool cover comes off
Make and model. Have you put it on correctly.?
Some heads are an anti clockwise thread to put them on, you also have to put a locking pin in place to stop the gear pinion from moving while you tighten it
May 31, 2016 | Garden
How do I get the spool retainer cap off
if it is a bump head then it has to go counter clockwise I believe . and YES they do tend to turn the engine if over tightened
Aug 18, 2015 | Ryobi 30cc 17" String Trimmer Zrry30530...
The screw underneath the head of my kitchen aid mixer is tight, but the head is still wobbling. It isn't a beater adjustment--I already tried that. The head of the mixer is tilted forward a bit--in
When you have the head lifted up the screw you can see in there from the front in the middle by the hinge is the head height adjuster. You need to set the height correctly now so that FLAT PADDLE just clears the bowl. Unscrew it anti clockwise to raise the head. Once that is done turn the machine upside down on a towel and check that the locking screw on the hinge pin is tight, it\'s right up inside the pedestal.
Aug 08, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
Hi wev put the bit on for the line onr mcculloch tm 250 petrol strimmer. Can u tell me how you get it back off thanks
Hold the big alloy nut above the trimmer head with a suitable spanner, then turn the whole head anti clockwise as you look at it whilst holding the nut, the complete head will spin off.
Apr 28, 2011 | Garden
Setting the correct time on Seth Thomas clock.
Correct technique definitely is CLOCKWISE ONLY. You are unbelievably lucky person if did not damage striking mechanism within 25 years while adjusting hands anti clockwise. If I'd have such a luck, I'd try to play lottery. :))
Feb 04, 2010 | Timex Watches
In a Zanussi FJS 1397 W machine does the drum pully fixing bolt have a right hand or a left hand thread ie does it unscrew anti-clockwise or clockwize??
It should be a normal right hand thread, unscrew anti-clockwise.
If you are having difficulty unscrewing it, then try applying some heat to the bolt head, and spray with WD40.
Hope this helps.
Dec 15, 2009 | Zanussi FJS1225W Front Load Washer
Bump feed on Strimmer head will not un screw. it Just turns constantly
your strimmer head has rounded where the bolt is located.You will need a new head so you have to break the plasic to get at the bolt and fit a new head.
Jul 19, 2009 | Garden
Bosch WFF1201
At the bottom of the machine on the front, there is a plastic cover (remove by turning the plastic screws a quarter turn anti-clockwise and pull off cover). The filter is behind this cover on the left hand side. It is unscrewed by hand anti-clockwise. Tucked into the plastic cover, you should also find the spanner to adjust the feet on the washing machine. good luck and rate me....
Feb 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
