Question about EUPSON Huawei EC122 3G Modem for CDMA2000 1X EVDO supports various Android Tablets
Zantel modem my laptop or any laptop not detecting device even after successfully installing the software
Zantel modem
Compatibility issue may be?
Apr 22, 2014 | Dell Computers & Internet
USB modem device driver software is not successfully installed on my Laptop for windows7.
right click on your my computer and then click on manage
then open device manager from left panel in the opened window
then list of all the hardware will open
be sure you have connected your USB modem already
check your hardware in the list of all hardware.
if its not properly installed then an exclamation mark will be in front of that driver.
right click on that driver then click on update driver software.
complete this procedure
May 20, 2011 | Computers & Internet
No modem detected in dial up connection in windows7
- Go to device manager and check for modem devices.
- If not installed then install required modem drivers.
- Shut down machine and re-insert modem in the slot.
- Go to Device manager and click on "Scan for hardware changes"
May 09, 2011 | Computers & Internet
Cannot use the mobile broadband even after installing the drivers..hp connect manager cannot detect the gps or modem.
If U have installed modem and it is showing in devices list as modem. Then create a dial-up connection directly for that modem using network manager
Mar 25, 2011 | HEWLETT-PACKARD Hewlett Packard HP 8440P...
Cannot detect a modem on a aspire 3680
Does the computer have a built-in modem?
Look for a square socket, with 4 (not 8) parallel gold-coloured pins.
If you don't see this socket, there is no built-in modem.
If you do, open the Windows "Device Manager", and look for "unknown" devices, and expand the 'Modem' category. It's possible that the correct software device-drivers for the modem have not been installed.
Double-click any "unknown" device, and then click 'Reinstall Drivers', and click 'OK to access the Internet to look for updated drivers'.
Dec 29, 2009 | Acer Aspire 3680-2682 Notebook
Epivalley SEC-8089 USB CDMA Modem from Tata Indicom- No Support.
you are in user mode dear log into admin mode and have all rights
Sep 06, 2009 | Computers & Internet
PnPDeviceProblemCode
Even i had this problem.
Follow these steps it may be of help to you.
1. Go to Device manager.
2. Insert the SD card.
3. When the SD card shows up in the device manager with an alert, right click and say disable device.
4. Go to Services and start PNP related services if it is not started.
5. Again right click and say enable device.
6. It shud update the driver software and your device may be detected successfully.
7. Enjoy :)
Cheers,
Raghu
May 27, 2009 | Dell Studio 1537 Laptop Computer PC...
Can't fax - modems not being detected
ok, a modem on COM8 ? Normally modems are on COM1, COM3. You need to fix that problem first. Most softwares are not setup to scan that high for the modem. (ps: COM2, COM4 are usually for other devices - in the old days, mice were on COM2). Follow instructions:
START
CONTROL PANEL
PHONE/MODEMS
Click over to MODEMS
Click on Proper MODEM
PROPERTIES
ADVANCED
ADVANCED MODEM SETTINGS
Change COM8 port to COM3
click OK, probably going to have to restart computer.
Let's see if this actually solves the issue. if it did not and you need more help, contact me through this site and we will proceed forward.
Jan 15, 2009 | Toshiba Satellite M30-S350 Notebook
Modem device detection
Could be a daffy modem, did you totally reinstall windows?
Nov 21, 2008 | Dell Inspiron™ E1505 PC Notebook
Windows Vista CDMA 1X usb modem not working
I faced the same problem i installed it. But got through it. See if this works for you too:
1. You have to install the software you downloaded from the tata site or from the CD you got with the MODEM. Do this without attaching the MODEM to the laptop.
2. Once done, insert the MODEM into the USB drive. The Windows will automatically search drivers for USB MODEM and QualCoMM drivers and install it.
After it shows the success message, click the Tata Indicom Dialer and check. The problem should not appear again.
May 31, 2008 | Microsoft Windows Vista Ultimate Edition
EUPSON Huawei EC122 3G Modem for CDMA2000 1X EVDO supports various Android Tablets Logo
Top EUPSON Computers & Internet Experts
David Payne
David Payne
Are you an EUPSON Computer and Internet Expert? Answer questions, earn points and help others
