Question about Nintendo Game Boy Advance SP GBA Red Gameboy Console
Rusted screw cant open battery slot because of rusted screw slot
    New Friend:
Well my friend i had the same problem and the only way to open the hatch is to get a very small screw flat driver and got to the kitchen stove and heat up the screw driver and melt the plastic around the screw and with a plier rotate the screw until out.. you will damage the baterry hatch but thats the only way.. look for a new one on ebay.
Posted on Jul 06, 2013
  • John Jul 06, 2013
Hello, I have an e-system 4213 laptop with a wobbly power connection. It probably just needs a bit of solder. I've removed the battery, disc, and every visible screw, but I can't get the machine to...
The top half and bottom half of the case may be clipped together besides being held together with screws.
There may be additional screws in the battery compartment or the DVD/CD drive slot.
Try separating both halves by pulling it apart near the battery opening or the DVD/CD drive slot.
Apr 22, 2011 | ASUS Computers & Internet
The calculator will not turn on
If your calculator does not turn on, then there is every tendency that the battery is weak. So replace the battery and try again. But if replacing the battery does not solve the problem, read further;
Check the batter seat. I mean the position where the battery stays, look if you will find any rust of the battery terminal (metal). Rust can prevent the battery from contacting the unit, preventing it from receiving power. Get a flat screw driver, scratch the rust off, fix the battery back in and try again.
If there is no rust, then there is probably some disconnection inside the unit. This can be between the battery terminal and the board. Get a screw driver and remove all the screw. Take the unit apart and check for any lose contact between the battery terminal and the board.
I hope the above makes sense to you.......
Good luck.
Apr 15, 2011 | HP 12c Calculator
Sharp EL-9900 wont start after replacing batteries.
when you said it suddenly died, do you means after putting in new batteries,it did not turn on at all? If yes, below are some reasons for this problem;
Regards.
Apr 11, 2011 | Sharp EL9900 Graphic Calculator
I cant figure out how to change the driver's side headlight
You have two screws at the top of the trim cover. remove them and tilt top towards you and remove from slots at bottom.
There are four screws holding the ring around the lamp. spray them with solvent and remove them the rest is just unplug and plug back in don't put it back upside down. (use a really good new screwdriver and if screws on ring won't come out after soaking tap the back of the screwdriver with a hammer to break rust in threads)
May 24, 2009 | 1998 Jeep Grand Cherokee
2 screws on bottom of iron are rusted
they do take a special tool. However I have used an allen wrench and it will remove them. Take them to a local hardware store or sears and get the same screw thread pitch in stainless steel and with a phillips or slotted head
Dec 30, 2008 | Rowenta Powerglide DM273 Iron
Rust at bottom of molding around ice & water opening on freezer door
Yes, slip a puddy knife or flat screw driver under the bottom edge and then twist and pull the trim out until it snaps free. There are two slots on the bottom that will easily accept a screw driver.
Oct 30, 2008 | Whirlpool Refrigerators
Screw rusted; cannot remove
ok for one, once you remove the screw hopefully you havent damaged the armature, which is the most important part,,,,1. get vice grips 2. try to get something to lock the sides down, ......question first, do you know if it works, if it does why are you taking the screw off, also if it doesnt its unfortunately probaly not worth fixing, if you need parts off of it just crush the side open..... if you come across another unit that has a screw loose, use silicon on the bolt and screw it will help keep it from rusting...
Jan 25, 2008 | Rainbow 75th Anniversary Canister Vacuum
Nintendo Game Boy Advance SP GBA Red Gameboy Console Logo
82 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
