Question about Garden
How to change fuel primer on ryobi rct2800 - Garden
4 Suggested Answers
  • 99 Answers
SOURCE: I need a fuel line and a primer fuel pump (plastic
You can order them directly through Ryobi and pay a small fortune or you can go to any small engine repair shop and purchase the fuel line by the foot. I believe your primer bulb can easily be replaced with what your local shop will have in stock. The parts from your local shop will probably out last the factory parts anyway.
Posted on Mar 08, 2009
#1 Taper
  • 1041 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • 64 Answers
SOURCE: Changing out fuel lines on Ryobi Trimmer, now when
the carb is plugged or the primer valve is sticky with gas varnish/gum
Posted on May 04, 2010
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need to know how and where the fuel lines connect on a Ryobi Sweeper vac RSV 1100
If your machine has a primer bulb then this is the sequence.
Fuel pipe from the tank, with the filter on. Goes to the FUEL IN side of the carb.
The suction side of the primer then goes to the FUEL OUT side of the carb.
The Primer 'blow' side then goes to the return to tank pipe.
To know which side the 'Suck' and 'Blow' side of the primer are, simply depress the primer and place a finger over one of the outlets to determine the order.
May 17, 2016 | Ryobi Garden
Ryobi rct 2800 e
could be a few things
air leak in your fuel tank
air leak in your pipe
even your zama carburetor
all can be obtained on ebay
Apr 14, 2014 | Garden
Hello, my Ryobi 410r tiller/cultivator needed new fuel line so I bought the fuel line, return and a new bulb primer. Unfortunately, I can't remember what hose goes where!!! Specifically, I've...
The primer pulls fuel through the carbruetor
So take your return line from the carb. and hook it to the inlet side of the primer and the other side
of the primer bulb transtions into the fuel tank.
You know when you have hooked it up right when you press the primer it fills with fuel and dumps back into the tank.
Jun 16, 2011 | Ryobi Garden
Has Ryobi RCS 3535A chainsaw a fuel bulb priming
The numbers you supply don't cross to an operators manual but that is typical of Homelite/Ryobi. I'm going to make an educated guess that it does not have a primer system. Other Ryobi saws with primer systems include it in the specification. The 3535A does not. Close scrutiny reveals no primer.
IMO fuel primers on chainsaws are one more source of problems. In the USA ethanol additives attack fuel hoses. Without a primer routing is from the fuel tank directly to the carburetor and much simpler to replace. Primers on chainsaws operate differently than 4 cycle engines too. No fuel is injected into the carburetor or engine, its only purpose is to ensure the carburetor is full of fuel,
Typical Fuel hose routing:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
Nov 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Needs new primer
You are searching for part number 181558. It is a snap in primer bulb with a piece of fuel line.
Oct 02, 2009 | Ryobi Cultivator
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
