Question about Garden
I have a coleman pressure washer model # PW0912500 - What type of oil goes into the pump housing , how much goes in, and how often does it need to be changed ?
  • 88 Answers
SOURCE: What type of oil do I put in the high pressure
regular motor oil
Posted on Aug 22, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
  • 583 Answers
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Posted on Sep 05, 2009
  • 56 Answers
SOURCE: what oil, how much oil, and how change oil on pump of ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
Posted on Jan 04, 2010
  • 760 Answers
SOURCE: what type of oil goes in a comet axd 3020 pressure
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
Posted on Jul 14, 2010
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
I have a Coleman 2200 6hp green tochemsa engine pressure washer and wanted to know what type of oil is used in the water pump? PLEASE LET ME KNOW.
The recommended oil is determined by the pump manufacturer (usually different from the engine), but most of the "consumer grade" pressure washers say you never need to change the pump oil. Maybe they figure something else will break before it needs new pump oil?
The little jugs of pump oil at home improvement stores are usually SAE 30W (non-detergent) crankcase oil. 75W90 gear oil seems like a better choice; I personally use synthetic marine lower unit gear lube in my pressure washer pump. It's a little more expensive, but I think the formulation gives better moisture resistance. Besides, the pump takes a fairly small amount, and I don't change it very often at all.
Bottom line- you almost certainly want non-detergent oil, around 30W crankcase/80W gear (since they use different scales, these are just about the same viscosity). Synthetics seem to be higher quality, and using marine grade lube gives me peace of mind.
The pump oil matrix here is illustrative- note the many substitutions allowed. The specific oil you choose probably doesn't make much difference, especially compared to never changing it.
Jul 16, 2011 | Coleman Garden
What type of oil does the pump use? how much?
8.5 oz. to the red dot on the site glass.
SAE 30 / 30 wt Non Detergent Oil from your local auto parts house.
Oct 02, 2009 | Caterpillar Cat Pump Pressure Washer Pump...
Hello:
Aug 25, 2009 | Briggs & Stratton Garden
What type of oil goes in the pump, and is the tube that comes out of it on the top of the pump supposed to be open or a covered vent??
Hello
10W30 is OK but it must be NON DETERGENT. Be sure you only fill the reservoir 1/3 to 1/2 full. Thee should be a cap on top.
Jul 05, 2009 | Coleman Garden
Coleman 1600 pressure washer
Remove spray tip and clean with a paper clip, Check pump oil resevior and add 10w 30 pump oil if needed, also look for turn knob ,usually black with -+[plus /minus symbols ] and turn towards plus for extra pressure. May need new pistol/wand assembly and make sure hose is clear by seeing if water will run through hose freely and generously.
Thanks Kf1013 and please vote me a Fix Ya!!!
JJ505
Apr 13, 2009 | Coleman Pressure Washer PW0881800
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
