Question about Uniden Bearcat Pro PC78XL 40-Channels Base CB Radio
Cb radio i bought a uniden pc78xl cb Ive hooked it up and calibrated it to the antennes i cna send very well but cant recive unless the other person is real close i belive i should be getting out alot better than that. ive tried grounding the antennes. and i dont know what esle to to do.
  • boon4ink Apr 28, 2009
    What number on the pc board is DSC? Do you turn it clockwise or counter clockwise to lower it?
    Thanks
    Brigadier General:
  • 6,966 Answers
Hi, A couple of switches and knobs you can check (if present in your rig): 1. auto noise/noise blanker switch - try off position; 2. dynamic squelch control - lower down setting; 3. RF gain - should be at max (clockwise); and 4. Delta Tune - normally should be centered. Hope this works out for you and give you an idea where to start. Good luck and pls post again how things turn up. Kind regards.
Posted on Aug 11, 2007
No sound unless the other person on the cb is close to me the further apart the lower the sound goes until its gone less than a mile apart
I hope you matched your CB radio in with the antenna. Most CB radios are good for about 5 miles without having a linear. Extra Power Source }
May 22, 2015 | Uniden Radio Communications
Schematic for pc78xL won,t turn on
there gould be a number of reasons for it not turning on but the one I am thinking of is the reverse polarity diode. If it is burnt your radio will not turn on look in the area of your where your power wires come in .You should see a single black zenner diode.Replace it and it should turn on .
Jan 21, 2012 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Need a shop
You may have ant. trouble if the SWR is hi
that feeds power back into the radio and
could damage it,lets hope not start with a
good ant.and maybe the radios are not hurt
to bad.
Good Luck
Sep 02, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
I have a bear cat scanner i moved out of nys to nc and now i cant find any codes wat can i do
The best database for locating your local frequencies can be found at:
www.radioreference.com
Another source is:
www.cityfreq.com
Not receiving on any channel
uou may a bad mic if not I would think the
autoamp is at bad.this means you will
have to thae to a shop.
Good luck
Aug 26, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Mic not Keying up
Sounds like you are not modulating well. try adjusting your amp.also, test your antenna for wire breakage and, make sure that your mic has good wires as well.
Jan 22, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Cant find utah 10 scanner codes
I dont know what you mean but here are 10 codes for Utah
http://www.bearcat1.com/radiout.htm
Those are for Utah
These are scanner freq's for Utah
http://www.bearcat1.com/utah.htm
Jan 12, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Scanner codes
Murry is this for a scanner, your heading lists a 40 ch CB radio. If your looking for freq's for your area,go here;
http://www.radioreference.com/apps/db/
If your looking for 10- codes and signals, go here;
http://www.nat-com.org/radio.htm
I hope this is what your looking for,, let me know and have a good day,,, Mechanic
Mar 08, 2008 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Uniden Bearcat Pro PC78XL 40-Channels Base CB Radio Logo
156 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
