Question about Rainbow Rainmate Air Purifier
Rainmate pulsates and is too annoying to use
Just got a Rainmate and at first if operated with a steady hum but after a couple of days started pulsating and making a jarring noise. This is annoying enough that I can't use it. Should it be operating at a steady pace or pulsating? Any way to get it to stop pulsating?
3 Suggested Answers
carter_p03
SOURCE: Rainbow Rainmate making a screeching noise!
just take it to ur local dealer they will replace it or fix it.
Posted on Feb 26, 2009
  • 1010 Answers
SOURCE: rainmate is not working, is there a warranty on it
Try to lubricate the fan bearings/bushings, it should help. If this does not help, check the repair price, or buy a new one
Posted on Mar 21, 2013
How do I clean the Rainmate?
Twist of stem from bottom, if excessive calcium or mineral deposits you can soak in vinegar. Keep hole in stem clean. Do not use harsh chemicals on any rainbow products it will compromise the materials. Vinegar should work.
Feb 03, 2016 | Rainbow Rainmate Air Purifier
Is the rainbow rainmate like a essential oil diffuser?
If the instructions don't say so, I would not do it. Oils can clog air purifiers that are designed for such pruposes.
Jan 17, 2015 | Rainbow Air Purifiers
Rainmate is not working, is there a warranty on it
Mar 21, 2013 | Rainbow Rainmate Air Purifier
How much water should i use
I run mine day and night while home and clean and re-fill it every morning. I also use one of the room odor eliminators in my Rainmate. Fill the water one inch above the line about an inch off the bottom of the water container.
Aug 20, 2009 | Rainbow Rainmate Air Purifier
Can you use other Fragrances
I have used other oil based fragrances and have had no problems.
Jun 06, 2009 | Rainbow Rainmate Air Purifier
I need a Rainmate instruction manual
I have one and it isn't much, it's just a single sheet.
If you want tell me what you need to know and I'll try to help you by telling you what I've learned while trying to understand how to operate the one I have.
Feb 11, 2009 | Rainbow Rainmate Air Purifier
I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I needed to know how safe is it to leave the unit running overnight, and how long does it take for the...
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful that the bowl is not near the edge of the surface as the spinning water might make it fall off the side. How long the water lasts is also very dependent on how large the room is that its in. Lastly you should be able to leave it run for 24/7
Jan 27, 2009 | Rainbow Rainmate Air Purifier
Rainmate question
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful not to place the machine too close to the edge of whatever it's on as it may fall off. The rainmate can be ran 24/7 (mine does :D)as a side note the only upkeep it should need (other than the water of course) is check the little hole on the bottem of the spinner. if that is ever clogged just punch it though with a toothpick.
Rainmate not working?
Remove the tip by twisting 1/2 turn and it will come off! use a Q-tip and clean it out! Replace and should work just fine!!! From time to time it gets gummed up!
Mar 17, 2008 | Rainbow Rainmate Air Purifier
Air Purifiers Logo
51 people viewed this question
Top Rainbow Air Purifiers Experts
jdthefixer
Andrew Taylor
Andrew Taylor
 Russ Hill
Russ Hill
Are you a Rainbow Air Purifier Expert? Answer questions, earn points and help others
