Sub woofer, duck call noise at start up!
Infinity SW12 sub was shipped and damaged slightly. now second after start up from standby it makes a duck call noise that last one second. Then works OK. Thanks, Tom A.
  • Audio Player... Master
  • 17,115 Answers
Contact the seller and the shipper and have it replaced. You wont be happy unless you do. You will always wonder about sound quality.
Posted on May 13, 2013
atang1
  • 734 Answers
SOURCE: My HKTS 7 Sub woofer makes no noise,the led burns
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Posted on Dec 04, 2010
simplemitch
  • 752 Answers
SOURCE: bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Posted on Aug 05, 2008
SOURCE: sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
Posted on Nov 21, 2008
  • 124 Answers
SOURCE: Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Posted on Nov 21, 2009
SOURCE: Subwoofer continuous buzz/signal noise
I just bought mine yesterday and have the same problem... did you find a solution (other than throwing it out the window)?
Posted on Dec 27, 2009
Tip
Infinity bass pro - Circuit diagram
See the circuit diagram for Infinity. sub-woofer. Electro help
on Jul 08, 2014 | Sony 182556522 1-825-565-22 SUB WOOFER...
My sub woofer making noise like machine gun w out connect toamp
Disconnect the sub-woofer and see if the noise stops, if so the amplifier is OSCILLATING and so produces the noise.This can be related to fault with the pre-amp or audio processing section. Try and heat up the circuit using a hair dryer and if the fault clears then there are faulty electronic capacitors. If leak is seen then the pcb must be washed after the capacitor is replaced which can solve the issue.
Mar 12, 2012 | Infinity BU-120 Subwoofer
My sub make a strange noise. It doesen't work anymore.Tks.
Strange noises can come from your amplifier or the sub itself. The most likely cause of the strange noise is the speaker just before it dies! If you have been using the sub-woofer at high volume levels then you probably have damaged it. Try testing the sub-woofer using a multimeter(on ohms setting) it should give you a reading from 8 to 4 ohms. Sometimes they may give readings as low as 1 ohm. When testing the speaker/sub you should hear a soft scratchy, thumping or clicking sound. This indicates that the speaker may still be working. If you don't have a multimeter try a 1.5 volt battery (say a AA), DONT USE HIGHER VOLTAGE BATTERIES they may damage the speaker! You will hear a clicking, scratching etc sound from the speaker which may indicate that it is still OK. If the speaker seems OK the problem may be in the amplifier, which I suggest you bring to a professional repairer. When buying speakers and amplifiers make sure the power handling of the speaker is equal to or greater than the amplifier output power. This should stop speakers from getting damaged. Make sure the speaker and amplifier specifications are rated in the same manner ie RMS PMPO Peak. A 100 Watt PMPO speaker will not survive the output of a 100Watt RMS amplifier!
Feb 08, 2011 | Audio Players & Recorders
X-220 cable is slightly damaged and not making constant contact with sub-woofer mate. Is there a repair where I can replace or cut open & fix the 9 pin cable? To me, the obvious problem is that the...
nothing is wrong with the woofer the connect is broken at the strain relief and the cable needs to be replaced.
You can replace the connector if you know the pinouts. You will need the connector and the schematic.
you may be able to find the pin outs configuration here.
http://pinouts.ru/
As for the connector this may take a search online.
Aug 07, 2010 | Logitech X-220 Computer Speakers
I have an infinity sw12 that is for some reason making a high pitched noise and some cracking noises as well. It does seem to work otherwise. I get the same noise when the cable to the stereo is unplugged....
It could be an internal "cold solder joint" however, if your lucky, it may just be dust buildup on the control pods and switches. Radio Shack sells "Tuner Wash" which will clean potentiometers (volume controls) and other electrical contact points. It's an inexpensive "try". Pull the volume and crossover knobs and lightly spray down with the wash. Let it set 10-15 seconds then move the control pod back and forth. Turn it back on and see if it's better. Hope this helps
Jun 26, 2009 | Infinity SW-12 Subwoofer
SUB WOOFER PROBLEMS
design u r aucostics properly
Jan 10, 2009 | Infinity BU-80 Speaker
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
Car audio sub woofers
is it the car vibrating or the sub making the noise ? if its the sub making the noise check all the screws holding in the sub and make sure they are tight or make sure nothing got sucked into your box if it is the car making the noise try using dyna mat to help stop the noise also check the surround on the sub and make sure there is no seperation of the surround from the cone
Aug 12, 2008 | Car Audio & Video
Bose acousticmass 15 sub-woofer making a noise
Jun 24, 2008 | Bose Acoustimass 15 System
536 people viewed this question
 Grubhead
Grubhead
