Graco Swyngomatic 6 Speed Open Top Swing With Mix 'N Move Toys Logo
A
Anonymous Posted on Apr 28, 2013
Sweetpeace graco swing parts
COMPLETE SEAT BELT WAIST STRAP AND CROTCH STRAP W/ BUCKLES
2 Related Answers
Anonymous
  • 12 Answers
  • Posted on May 26, 2012
SOURCE: We need the base to a Graco Sweetpeace baby swing.
Under the "Add your solution or ask for clarification" window click on the camera icon to add photo.
Anonymous
  • Posted on May 14, 2013
graco swing makes grawling noise no music sound at all
2answers
How do you remove canopy from graco sweetpeace infant swing in order to remove sleep cushion/material for washing?
You need to remove the center of the part that connects to the chair. Use a thin screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off
6helpful
Hi there. I have a smart trike classic.I would like to change it to 15month+ and have remved the sunshade and backing. However is there a seatbelt for it at this stage I cannot work out how to take the...
  • For 15 months you remover the headrest.
  • The safety rails come off.
  • As for the harness - there is a single strap that will go around your child's lower abdomen and wrap behind the seat. This strap weaves into a hole on a strap that runs from the front of the strap around your child's waist, under the seat itself and up to the waist strap in the rear. So basically the way the harness is set up for 10+ months old your gonna remove the over the should part of the harness and run the two buckles in front behind the seat.
Regards, Tony
Apr 27, 2011 • Toys
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOPâ„¢ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITEâ„¢ SWING On the bottom of the contoured plastic seat
  • SWEETPEACEâ„¢ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHEâ„¢ SWING + ROCKER On the underside of the housing
  • DUETCONNECTâ„¢ SWING + BOUNCER On the underside of the housing
  • DUETCONNECTâ„¢ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGERâ„¢ Inside leg near Rock Lock
  • DUET ROCKERâ„¢ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAYâ„¢ INFANT SWING On tubing on bottom of unit
  • COZY DUETâ„¢ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDERâ„¢ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 • Graco Toys
Need a user manual for graco sweetpeace newborn soothing center
I received a Sweet-peace newborn swing and the A/C plug is pushed in. Is there a way to retrieve it? How hard will it be to take the swing apart and retrieve the plug? You can reach me at my e-mail at: [email protected] Thank you for your time.
7helpful
2answers
1helpful
Car seat straps
I have the same problem with mine. It's an easy fix. Unlock the straps (pull the little gray release tab) and then pull firmly upward on the lap belt opposite the loose strap. To reword: If your left shoulder strap is the loose one, go the right side of the seat, where the LAP belt comes out of the seat, and pull firmly upward on that part of the belt. It will pull the slack out from the other side. I hope that was helpful.
14helpful
2answers
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Top Graco Baby Gear Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jay Finke
Jay Finke
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
