Question about Bosch Dishwashers
Bosch smv50c00gb/03 No water being pumped into machine however the pump is fully working and pipes are not blocked
Krazytech
  • 725 Answers
SOURCE: Cannot get access to Water pump to clear it.
the sump is in the bottom center front. a retangle screen with a center filter should unscrew counterclockwise the drain pump is hard to access but if you want to let me know and I can walk you thru it..let me know if this helps
Posted on Aug 25, 2007
BIKER T
  • 909 Answers
SOURCE: Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Posted on Oct 08, 2007
  • 213 Answers
SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Posted on Nov 20, 2007
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
RepairClinic
  • 32 Answers
SOURCE: Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 11, 2009
Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Hi ive got a Bosch exxcel 1200 exspress washing machine (model num WAE24464GB/03) , the day we moved it worked , when we tried it at new home it wouldnt pump water out . ive cleaned all pipes in &...
Bosch exxcel 1200 exspress washing machine This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 13, 2011 | Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
Bosch WFF 2001 has finished a wash cycle but the water will not drain or spin away, cannot open the door. There is no apparent filter trap to empty, help!
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Nov 06, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch excel 1200 express will not rinse,drain or
Do the following.
  1. Switch off the machine and disconnect the mains power.
Oct 26, 2009 | Bosch Washing Machines
Bosch Nexxt 700 won't drain water after washing cycle. Switched to Spin mode, only hear humming noise. Drainage pipe is clear.
Do the following.
Oct 23, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch 1400 Exxpress washing machine : Turning off after a few sec
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 19, 2009 | Bosch Washing Machines
What does error f04 mean on a bosch washing machine
It means that the water is not draining fromthe machine inthe time allowed by the controller.
Oct 17, 2009 | Bosch Washing Machines
Bosch washing m/c wf2000 pump not working
it may be as simple as a blocked pipe. Check the outlet under the sink it may be full of hair/fluff etc. If you can disconnect the outflow pipe from the u-bend under the sink, first check that the end of the outflow pipe is not blocked, then check the u-bend for blockages. If these are both clear then the pump itself may have a blockage. If you know how to get to the pump, then ask someone to help you take the outflow pipe away from the pump so you can check the pump and pipe for blockages. Be prepared for plenty of gushing water if you remove the pipe away from the pump, and have a pot or something ready under the sink for when you check the pipe at that end. I hope this helps.
Oct 23, 2008 | Washing Machines
Bosch WET2820 integrated washing machine. Cycle gets stuck on "anti-crease 1". Have followed instructions in manual for unblocking drain pipe, hose and suds pump although problem (doesn't drain...
was a hair clip stuck in the drain pump..
fixed like this:
Use the small draining pipe that is fitted to the filter housing to drain the water down.
Take the filter out from front bottom.
Inspect and remove any debris blocking the drain pump.
et voila! working!
Jul 10, 2008 | Bosch Washing Machines
Dishwashers Logo
142 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
