Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
96300 41001 073
I need the power adapter size
I know I need a 5 volt dc power adapter but I don't know the size of the end piece that connects to the speaker can you help me thank you.
Jean, take the speaker with you to the source or electronics shop and they will match you up with proper universal adapter.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
power adapters
Amazon com Universal 5V 1 2A AC Power Supply Electronics
5V Power Adapter eBay
http://www.walmart.com/c/kp/universal-ac-dc-adapters
Feb 27, 2016 | Audio Players & Recorders
I have a pair of acoustic research "active partner" speakers in need of a power adapter. Above the entrance of the plug in print it has DC 11.5 V. Need a compatible adapter.
DC 12v adapters are common and I think that would work. The similar "Powered Partner" speakers used a 14v DC adapter. Just check the size of the plug and the configuration (center pin is +). Radio Shack and other sellers have universal adapters.
Sep 29, 2013 | Acoustic Research Audio Players &...
How do I upload pictures from my Samsung Strive onto my Gateway laptop comuter.
1. Purchase a micro-SD card with an adapter for a normal-sized SD card.2. Plug in the micro-SD card to the back of the phone. Make sure the power is off when you do this, of you could unintentionally harm your phone.3. Power back on, and transfer the pictures to the micro-SD card.4. Shut the phone back off and remove the card again. Place it into the adapter.
If your Gateway laptop has a SD card reader:
5. Put the adapter into there.6. Transfer the pictures to you computer. Done!
If your laptop doesn't have a SD card reader:
5. You'll need to purchase a second adapter that adapts the regular-sized SD card to a USB port.6. Following the manufacturer's instructions, put the SD card into the second adapter.7. Transfer the pictures to your computer. Done!
Best of luck, Juseppi
Jul 09, 2011 | Samsung Strive A687 (88516535667)
Need to buy a replacement power adapter for this model, can you tell me what the dc output and connector size is - Zyxel P660HW-D1
Dc output is 12v and 1amp.
You can buy power adapter for Zyxel P660HW-D1 from nearest computer shop or from internet.
It's power adapter needs 12v and 1 amp.
Let me know if you need further assistance.Thanks for using FixYa.
Jun 13, 2010 | Zyxel P660HW-D1 Router
Toshiba Portege 7100 AC Adapter
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
Jun 11, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Adapter plug size
Wal-Mart ectronics dept. has an "Universal DC Adapter Kit" it will have various size adapter plugs and a variable setting to adjust DC Voltage. It also should have a switch to set the polarity. I used mine to power several different devices. It was well worth the money I spent as opposed to buying a actual DC Adapter. Subsequently, the kit from Wal-Mart was far cheaper than the real deal.
-marshall.
Albuquerque, NM
Aug 28, 2007 | RCA DRC620N Portable DVD Player
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
21 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
