Question about Hobart HL600 Legacy Stand Mixer
Hobart mixer error codes
Hello, we're having an error code "OLU" with a HL600. Anyone knows what this means and how to solve this?
What does 0c2 error code in Hobart mixer HL600
It is over current issue due to low supply voltage or batch size too big or frequency drive shorted.
Sep 07, 2015 | Hobart Food Mixers
What is a good source for a reasonably priced 200-240V 2.7 HP switched reluctance motor found on Hobart's HL600 mixers?
Baldor no longer manufactures that motor. Hobart would have to install a kit that includes every electrical component in the machine. Be careful if you find a used one, they have a very fragile encoder on the rear of the motor.
Aug 19, 2015 | Hobart Food Mixers
What is the error code b-in
It's meant to tell the operator that the bowl is not in proper operating position. If the bowl is in the proper position then the bowl in switch may be bad.
Jul 01, 2015 | Hobart HL600 Legacy Stand Mixer
Pushing the start button, a code of 6_9d appears. What is the issue and how can I fix this?
It's telling you that the bowl guard is open. If the bowl guard is in place and closed then you could have a bad bowl guard switch.
Check www.hobartservice.com for your local Hobart office.
Aug 21, 2011 | Hobart HL600 Legacy Stand Mixer
What is error code 99 for a hobart HL 600 mixer?
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Jan 29, 2010 | Hobart HL600 Legacy Stand Mixer
Keep getting error code 23 when trying to start mixer
i will try to help, always include ml# with problem description on any hobart pc. of equip. which is located on the info. plate. there are 2 v.f.d.for this mixer ,sr drive being 1st generation, and gen. elec drive 2nd generation, on the sr drive err23 indicates a motor stall condition there are 6 most likely causes for this err. 1st, batch size too large,ck. capacity chart. 2nd,encoder malfunction. 3rd,motor malfunction. 4th,drive malfuction. 5th,1 con coil malfunction. 6th,2 cr malfunction. if this does not help, repost problem and i will ck. to see if i can be of anymore help, please dont forget to vote for me thanks, monomoy
Oct 05, 2009 | Hobart HL600 Legacy Stand Mixer
Manual for a Hobart H600, please. M Martinello 2347 Pillette Windsor, ON N8T 1P7 519-566-6677
Hello, i´m in mexico, i have a h 600 mixer from hobart. I need to know what kind of lubricant need for gear box and planetary system
Jun 28, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Mar 11, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
Nov 14, 2007 | Hobart HL600 Legacy Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
134 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
