SOURCE: To repair my Haier washer
its hard to know without seeing it but check the belt,carbon brushes if it has them,not sure where to get parts
SOURCE: Water Draining off Automatically
Sounds like you have a siphoning problem. Click on the following link for instructions on how to determine if this is the case:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If this is not the problem, or if you need further advice, please post back and let me know. I hope this helps you.
SOURCE: my lg washing machine is a semi automatic model
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
SOURCE: onida hydroshakti 60E washing machine
Yes - you can do both at once.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Our Electrolux washing machine of
if the noise your describing is a grinding rumbling sound when you turn the drum it is likely the main drum bearing have failed. you can usually detect play in the bearing by lifting the drum and seeing what movement there is compared to door seal area .1mm is the maximum 2mm would give 6mths to 12mths 6mm failure imminent.
