Onida Semi Automatic washing machine hydrofall 70S
Spinner not working
  • 351 Answers
SOURCE: To repair my Haier washer
its hard to know without seeing it but check the belt,carbon brushes if it has them,not sure where to get parts
Posted on Mar 02, 2008
jsrock516
  • 5911 Answers
SOURCE: Water Draining off Automatically
Sounds like you have a siphoning problem. Click on the following link for instructions on how to determine if this is the case:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If this is not the problem, or if you need further advice, please post back and let me know. I hope this helps you.
Posted on May 22, 2008
  • 343 Answers
SOURCE: my lg washing machine is a semi automatic model
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Posted on Apr 18, 2010
caroldon
  • 17130 Answers
SOURCE: water gets drain cannot remain
The drain is pull the knob which will pull up the drain valve. So if this is not working then the connecting bowden is broken and is not connecting the link to the bottom drain valve.
Look at the bottom and connect. Clean the drain valve, if choked.
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: onida hydroshakti 60E washing machine
Yes - you can do both at once.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
My Onida Semi Automatic Washing machine Hydrofall 70S model Spinner is not working
onida semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
Apr 28, 2013 | Washing Machines
Dryer not working
Please mention the model of the machine. If this is a semi type then the motor or the timer switch can be faulty or if this is an automatic type it can be a fault on the program timer unit.
Jan 15, 2013 | Haier Washing Machines
BonJour 3450-70 Fresh Spin Automatic Salad Spinner
how do you put the lid together just below the area of the top? Friend went to wash spinner and pulled on top and now I can't get it to sit flush anymore. It seems there a two plastice prongs inside top that must be released. Help please. Love this spinner but now can't use!
Nov 18, 2012 | Washing Machines
My washer had stopped spinning about two weeks ago, we replaced thecoupler and it worked fine but today it stopped spinning again
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Washing Machines
I need a user manual of whirlpool semi-automatic washing machine
whirlpool semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
Sep 22, 2010 | Whirlpool Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Feb 29, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
