Bosch avantixx 7
Display is showing picture of key even though the door is locked and wont start
Krazytech
  • 725 Answers
SOURCE: door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Posted on Aug 13, 2008
  • 6277 Answers
SOURCE: I have a Bosch Avantixx 7 WAQ 2031XEE washer and
Although you mention the make and model on this posting we still cannot supply direct, sorry ;-0(
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jun 16, 2011
caroldon
  • 17130 Answers
SOURCE: my bosch classixx6 1200 express
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Posted on Aug 20, 2011
SOURCE: Hi, I have a Bosch
My Bosch Avantixx 6 VarioPerfect smells and therefore the washing smells.Any solutions?
Posted on Aug 25, 2011
robert_doku
SOURCE: Hi. My Bosch Avantixx 6
Hold the Start/Reload button for 6/7 seconds till the symbol disappears.
Posted on Jul 21, 2012
My Bosch AvantiXX front load washing machine has finished the wash and now it has locked on me and I can't open it. How can I open the door?
hi Suzanne.
i have had a look around the internet and found that there is lots of ways to try and open it.plus there is people on youtube showing how to open a door.
so if you go to this link and pick the one you think would be the best one for you to try.
Bosch AvantiXX front load washing machine door wont open Google Search .
or this one.
How to open washing machine door that won open normally
Nov 20, 2017 | Bosch Washing Machines
89 T-BIRD WONT START, TURNS OVER, THEFT LIGHT BLINKING, OWNER LOST KEYS, HAD NEW KEY CUT STILL WONT RUN
I would go after the door lock first. Older fords have a switch on the door lock that disables the alarm. They tend to break and fall though. I have replaced them with a momentary on/ff switch.But the alarm would go off when opening the door. On some older ones(85,87)(no keypad) I could disconnect the security module and it did just fine.
Jun 26, 2016 | 1989 Ford Thunderbird
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Apr 26, 2015 | 3100L 1way Security System
My 98 kia sportage wont start
It sounds like the key sensor in the drivers door is malfunctioning, the drivers door is the only door that can enable/disable the alarm, if you try to unlock any of the others it will trigger the alarm.
Sometimes with my Kia I have to (without opening the door), cycle lock and unlock several times before the alarm is disarmed.
Have you tried this is succession, with all the doors locked:-
put the key in the drivers door, turn to lock and then to unlock, the alarm should disarm.
Also, if any of the door locks are jammed, the alarm will still activate when you try to unlock the drivers door.
If that fails and the alarm still activates, then it's a problem with the key sensor in the door.
Mar 30, 2014 | 1998 Kia Sportage
Lock key on
Select a cycle then hold the start button until the key goes off, you have set the child lock by mistake.
Dec 03, 2011 | Bosch Washing Machines
How do i unlock the "child lock" in my Bosch
Touch the childlock key for about 5-8 seconds and its unlock!
Sep 12, 2011 | Bosch B335-3 SWIVEL MOUNT FOR 774/932...
My washing machine is beeping and showing the key light and not turning on. The door opens though but it seems to be saying its locked!? It doesn't show the cycle time either. How can i get it to go...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch, but you didn't specify the model number. It sounds like the "child lock" selection has been activated, either intentional or accidental.
To reset it on many Bosch it is as follows...(if this fails, please provide your model number)
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
**Many times you can also push and hold the start key for several seconds and this too will deactivate the selection...on various models**
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for choosing FixYa. I'll need to watch for your reply if that doesn't work or before moving forward.
Regards,
Macmarkus :)
Aug 16, 2011 | Bosch Washing Machines
Washing Machines Logo
Top Washing Machines Experts
