Lg direct drive 7.5kg WM-12225FD
My machine leace a small sticky ball type residue randomly on the clothes that have been washed, how can this be stopped and problem resolved completely
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Posted on Oct 15, 2007
BADBOYJAY
  • 264 Answers
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
SOURCE: lg wm-14445fds direct drive 8kg washing machine manual
You can get the manual here:
http://uk.lge.com/products/sidemenu/list/homeappliances|washingmachine|steamdirectdrivewashingmachine_PRD|MANU_manu.jhtml
Just curious - what happened when you tried to get in touch with LG? Also, did you call, email, what?
Posted on Aug 12, 2008
Jidza
  • 24 Answers
SOURCE: My washing machine is leaving
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Posted on Jan 24, 2009
My LG direct inverter has a bad smell &; now has left the washing with gunk on the clothes
sounds like the direct drive invertor type motor is going bad you may want to contact LG directly to have this part replaced
Nov 02, 2016 | LG Washing Machines
What causes the EO error message
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Oct 04, 2014 | LG Washing Machines
I have my LG Fuzzy Logic for 3 years now. Lately after washing my clothes I see that there is black particals stuck to my clothes after washing. I comes off when I shake the piece of clothing. I has a...
It's just a build up of residue. To clean out your drum, run a hot cycle (obviously with no clothes in the machine) with half a cup of vinegar then when the cycle is finished, wipe out all the residue, and trust me there will be alot. I do this every 3 months to give the drum a good clean out.
Oct 29, 2010 | LG WFT1071TP Top Load Washer
What causes an lg direct drive not to spin
your tub needs to be totally empty of water first,if it is then open the top cover and run the diagnostics on the unit,if this fails then the control board is defective
May 29, 2010 | LG WM-2277HW Front Load Washer
Sticky smelly sour clothes that were just washed in the horrible LG washer. Never recommend this crappy appliance. How do you get this company to be responsible? I got an extended warranty thru GE that...
You have to leave your door and detergent compartment open after every wash. Try using Tide washing cleaner for the machine to get the smell out first, then follow the steps above.
Jan 30, 2010 | LG WM-2277HW Front Load Washer
Lgwm2277h front door problem
The latch on the door had to be change
Sep 16, 2008 | LG WM-2277HW Front Load Washer
Lg wm-14445fds direct drive 8kg washing machine manual
Aug 07, 2008 | LG WM-2277HW Front Load Washer
Lg wm1814cw drain error
Click on LG (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Nov 28, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
