Question about Car Audio & Video
Pioneer power amplifier gm 62 compatibility
What will be the best sub-woofer for gm-62
AUTOSOUNDINS
  • 232 Answers
SOURCE: sub woofers dont give clear sound on high volume
THE AMPS PERFORMCE IS DIRECTLY RELATED TO THE STATE OF THE BATTERY AND THE CONNECTION FROM THE AMP TO THE BATTERY, CONNECT THE AMP DIRECTLY TO THE BATTERY TO SEE IF THE SAME PROBLEM EXIST OUTSIDE THE CAR
Posted on Aug 28, 2008
SOURCE: i have a pioneer gm-x404
The wiring is fairly straight forward. Along the top row of the ten pin plug =
(Left to Right)
Front Left positive,
Front left Negative,
Control wire from your stereo head unit should be thin blue wire sometimes listed as Remote Wire this switches your amp on and off via your head unit so you don't run your battery flat,
Front Right Negative,
Front Right Positive.
Bottom Row=(Left to Right)
Left Back Positive,
Left Back Negative
Centre Nothing
Right Back Negative
Right Back Positive
These are all inputs from your head unit.
To bridge from 4 channel to 2 you connect
one left speaker to Ch B Left Positive and Ch A Left Negative
one Right speaker to Ch B Right Negative and Ch A Right Positive
Ten Switching the Input Select switch to 2CH
Alternatively if your unit has RCA's on the back of the Head unit you can use them to run your subs.
Hope that helps.
Posted on Sep 25, 2008
djmaximus_87
  • 26 Answers
SOURCE: What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Posted on Jun 10, 2009
  • 182 Answers
SOURCE: I need a schematic for the pioneer gm-62 mini car
here is a link
http://akamaipix.crutchfield.com/Manuals/130/130GM6200F.PDF
Posted on Jun 29, 2009
  • 1015 Answers
SOURCE: Sony X-Plode amplifier. NOT working
It is possible if the model amp you have is bridgable to 1 channel. Usually when you bridge an amp you will need to hook one wire to the positive side of one channel and the negative side to the other. You will need to consult you user manual for the amp or get the manual from the sony website for instructions on how to bridge the amp or if the amp is even bridgable.
Posted on Oct 11, 2009
HOW do I install my Pioneer 4 channel power amplifier GM X 84 along with my pioneer DEH-17 cs player .? A wiring diagram is needed
If you are using two amplifiers used one the amplifier to power a sub woofer on you though frequency the other amplifier willpower the rest of speakers make sure your power wires are separate and the both run at 15 to 20 A
Aug 09, 2014 | Car Audio & Video
Amp 2400 watt sub woofer
Use this link and print it up and take it to a local car stereo shop to get ideas, then shop for it the way you want .http://reviews.cnet.com/car-amplifiers/pioneer-gm-x924-car/4505-6726_7-30233385.html
Their not bad amps but don't exspect a lot.
Sep 24, 2013 | Pioneer GM-X924 Car Audio Amplifier
How many total watts
Hello
The power rating for this amp is as follows.
Two channel: Sub woofer: Min 35Watts
Two channel: Other than sub woofer : 70Watts
One channel: sub woofer; 100Watts
One channel: other than sub woofer: 200Watts.
OK.
Dec 17, 2011 | Pioneer GM-X332 Car Audio Amplifier
Are subfoofer ts-w308d2 and amplifier GM-5300T compatible with each other?
Yes. You will be able to run this setup with the sub bridged across both channels of the amp, which will give you more power (which the sub will be able to handle: 380 watts rms), or with the sub wired to a single channel, which will give you less power (125 watts rms). The sub can handle 400 watts rms.
Mar 18, 2011 | Pioneer GM-5300T Car Audio Amplifier
I wired my dvc sub woofers to 4 ohms and bridged my pioneer gm-5400 amp and it cuts off when i turn the volume up.
1. Check if your power cable is of adequate Gauge 2. Try turning the volume down from the amplifier gain level 3. You could even check to see if your battery is on it's way out and just cant feed the amplifier with the power it needs. (very rare case) do the car lights dim when the volume is not really that loud? 4. There could be an error on the way the subs are connected, double check that you have absolutely configured them to run @ 4OHM. could be checked with a multimeter before connecting to the amplifier. 5. Another rare case is sometimes the fuse block expands when it heats up on loud volumes and can have contact issues so try tightening the socket that the fuse goes into. 6. It could also be a problem with one of the sub woofer or even the amplifier. more details might help me better understand the problem, but i hope this helps. dreamsystems
Feb 06, 2011 | Pioneer GM5400T 2-Channel Bridgeable...
I parelled one 15" q power subwoofer to my brideged pioneer amp.The amp got really hot and blew a fuse.How should I wire my dvc subwoofer to the briged amp.
Hello sir, hi, YOU DON'T bridge no more speakers, this upsets the impedance load of the amp. to install another sub-woofer, get another amplifier. You may have damaged your power amplifier, If you experience repeated fuse blows, your power amplifier is now SHORTED. This needs IC amplifier replacement.
Aug 19, 2010 | Pioneer GM-5300T Car Audio Amplifier
Help with hookup
I am assuming you are driving a sub-woofer. Run the amp bridged at 4 ohms. So a DVC(dual voice coil) 8 ohm sub with voice coils wired in parallel would give you a 4 ohm load. Just make sure the sub can handle at least 300 Watts Peak.
Dec 17, 2009 | Pioneer GM-3300T Car Amp
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Sub woofers dont give clear sound on high volume
Aug 28, 2008 | Pioneer GM-X924 Car Audio Amplifier
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
