How to open rm-ga008 - Televison & Video
How to open Sony remote control device RM-887
and why does it need opened . not made for self service .
Dec 23, 2014 | Sony Televison & Video
NOKIA3110C PPIRM 237 MODLE SOFTWERE DOWN LOAD
Hi just download and install NaviFirmEx_v1_6_1.Open the NaviFirmEx_v1_6_1 application to your desktop.After you will see different model number with their respective Rm so choose 3110c Rm-237 and select your product code.In case if you can't find your product code just download 7.30-0544311(rm-237:07.30-051)Thanks
Mar 01, 2013 | Nokia 3110 Cellular Phone
How do you Open Sony rm-yd059
SONY RM-YD059 remote is easier to disassemble then other models. Slide battery cover open 1 inch or half open. Using a plastic toothpick or similar device pop cover using the groove. There are three sliding locks on each side. You will now see six screws holding halves together - remove. There are six more clips holding remote together. Starting at the top working towards the bottom, there are three per side, location of clips at red and blue buttons, at between 4&7 and 6&9 rows, and finally at muting and jump buttons. Voila - Happy cleaning. Note: directional ring is keyed with thin and fat tabs, fat tabs are positioned towards the bottom.
Feb 04, 2013 | Sony RM-YD059 Remote Control 148947911
Need instruction manual for sony rm 841 remote control
How can i tune chanells. How can i open the menu for tuning with RM-841
Nov 07, 2012 | Sony Original Tv Vcr Remote Control Rm-841...
Open remote control sony RM-GA011 for cleaning
how can i open remote control RM-GA011 SONY REMOTE
Oct 01, 2012 | Sony Televison & Video
04 rm 85 surging at mjd range runs smooth wide open
check your reeds, needle and jets in your carburetor
Sep 11, 2012 | 2005 Suzuki RM 85
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
