Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Toshiba Theaterview TP48E60
Occasionally the picture will become rounded at the corners showing some color striping. This usually clears itself. Recently the picture began shutting off momentarily with good sound. Now the picture is also abruptly closing in and then popping back to full. I've checked several online troubleshooting sites looking for a similar problem. I'm thinking it might be the convergence board. Can repairs/adjustments be made in the service mode or is replacement of the board recommended?
  • 398 Answers
Replacement of the board is never recommended, unless the board caught fire and is all burned up. If the convergence circuits quit working then you still see a picture, but the 3 colors just dont line up with each other. The picture shutting off, closing in and then popping back to full suggests a loose solder joint in the horizontal deflection circuits. This is something that cannot be adjusted in the service mode and the repair should be handled by a qualified tech.
Posted on Aug 07, 2007
SOURCE:
Vizio E470i_A0 shutting off after loosing horizontal frame sync
It could be several things but I'd start with a main board, the fact its shutting off kind of drives me away from Tcon as that shouldn't shut the set down if there was an issue there, it also could be power supply, you could test the voltages from the board once it starts giving issues and if some are off then change the power board.
Dec 10, 2017 | Vizio Televison & Video
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
When I turn the tv on the picture is perfect. After a while I see 2 translucent stripes on the right side of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 02, 2016 | Televison & Video
My Sansui DTV2798 Color Is Not showing Clear! 1 Day I Turnt The TV Off Then When I Turnt It Back On, It Click Back Off & Every Since Then The Color Has Not Been Clearer Since! When There Are Dark...
It sounds as if the color controller/circuit board is becoming sensitive and may soon disconnect. Don't be surprised if someday soon, the picture goes very dark or vanishes completely. Have a technician check it out with his test equipment to locate the exact problem.
Jan 31, 2018 | Sansui 27 inch TV
Nikon D200 has become nearly impossible to grab images
False low-battery warnings, focusing, and metering problems may be the result of poor contact between the body and certain lenses. Try removing your lens and thoroughly cleaning the contacts. I would recommend using a contact cleaner, but rubbing alcohol will also work. Remember that the whole ring needs to be cleaned. If that does not work, try scraping the battery contacts.
Feb 01, 2010 | Nikon D200 Body Only Digital Camera
Sharp 46" 6 months old see rainbow colors from left to right
Did he change the big video board?The main backlight video baord that the prob.
Oct 23, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Monitor distorting in screen halves after warmup
It probably isn't worth repairing as the cost will exceed what you would spend on replacing it.
Sep 11, 2009 | ViewSonic VP201b 20.1" LCD Monitor
Color pictures have white stripes on them. The
Try running the cleaning cycle on the printer, either through the printer software or via the controls on the printer itself. Sometimes print heads dry out and cause stripes.
Jul 07, 2009 | HP PhotoSmart 7260 InkJet Printer
Lost the picture
RESOLDER CIRCUIT BOARD LOOK FOR CRACK SOLDERING AT TRANSISTORS FOR CONVERGENCES
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
261 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
