Question about RCA RTD300 DVD/VCR Home Theatre System System
Won't do anything
My receiver says lock on and i can't even turn it off, i tried to unplug but after plugged back in it still says lock on! anyone know what i do to fix this?
  • mcdowelld Sep 16, 2009
    i just bought a rtd3131 system. it did not have a operaters manual with it. can you help me ?
On page 5 of the user manual, there is a note about a "Child Lock". The solution may be to put the remote in the VCR mode, and press the ON/OFF Button for 8 seconds and the word "LOCK" should go away
Posted on Nov 11, 2007
SOURCE:
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
How do I get sound to my Sennheiser RS120 wireless headphones when it shows as working properly?
Dirty volume control on headphones. Try moving the volume control back and forth several times to clean off the contacts.
Dec 14, 2014 | Sennheiser RS 120 Consumer Headphones
Motorola DCT700 won't power up.
its working correct... thats sounds normal
now you just need to wake it up. turn it on using the remote supplied by your cabe operator. if anything it may be your remote that isn't working. does a "cbl" light or anything light up on the remote when you press the cable box power button? if not try to find out how to put it in cable mode and try again.
wish i had more info
good luck
Aug 12, 2012 | Arris DCT700 DTV Receiver
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
MojogiMy GHD1621F2 freeview recorder is frozen on one programme, won't respond to the remote at all (have new batterys) and won't respond to buttons on front. Turning off and on doesn't work...
Hi mojogill,
It sounds like the receiver may be locked up. If the buttons on the front do not work, then try unplugging the receiver for 5 seconds and plug back in then check to see if everything is working fine.
If you need any further assistance with this, feel free to contact me at [email protected] Thanks!
Tommy Faust
DISH Network
May 25, 2011 | DISH Network ViP722 DTV Receiver /...
''Key lock on'' and can't eject dvd
Only with the remote.
Or via the menu ( child lock disable ) or keep pressing the play button
Jul 23, 2009 | Televison & Video
My DVR-625, wont even turn on.
at the time the hard drive problem came up the receiver would of went into recovery mode this can take a good hour for it to fix and can do nothing until it would finish on its own and take care of. Doing the power reset is just like unpluging the receiver. Try unpluging again for 30 minutes and plug back in again and just wait receiver should come back on its own. Don't hit any buttons. If not will have to send out to dish for repair. 800-333-3474 dish
Nov 22, 2007 | DISH Network DVR-625 DTV Receiver /...
RCA RTD300 DVD/VCR Home Theatre System System Logo
216 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
