Question about Cell Phones
Samsung SAMR600 Won't complete powering on
I have had problems with my Samsung samr600 not holding a charge for quite a while. now when i try to turn it on it shows the Samsung screen then goes right back off. If i continue to hold down the on button it just flashes on-off-on-offIs this a problem with the battery or the phone it's self ?
silentspoon
  • 62 Answers
SOURCE: iphone wont turn on at all help
Have you tried a hard reset? If this doesn't work, have you tried plugging the phone into iTunes to see if you can do a full restore?
Hard reset:
  1. Press the home button (the big circle below the screen) and the sleep wake button (the button on top of the iPhone) simultaneously.
  2. Hold both buttons simultaneously for a few seconds, Ignore the "Slide to power off" and keep holding
  3. The iPhone should now shutdown automatically - (fade to black)
  4. Turn the iPhone back on by hitting the sleep/wake button.
  5. You should now see the Apple logo, your iPhone is restarting and thus booting up.
Posted on Mar 07, 2008
SOURCE: Lg EnV VX9900 CLR Button Resets phone.
When you hit the clr button it will go back to the screen you where prior. When your booting up, it will show the Vcast screen. Maybe check your backlight setting.
Posted on Jan 27, 2009
  • 89 Answers
SOURCE: phone only works while plugged in
to get the watte out of your screen is a difficult proccess but very possible...
get a very small screw driver
have somepatience and time
steps
1open phone
2on the outer sides of the speakers there is a small tab slide the screwdriver underneath that and scrape it off on both sides
3then remove the screws hiden under those tabs
4do the same for the bottom corners
5slide the screwdriver under the metalic silver lining around the front between the silver and black, slide screwdriver around until whole top pops off, proceeed with caution there are wires attached to the screen
6remoe any water very carefully with a cloth
7replace cover, screws, and tabs
8celebrate a job well done
Posted on Apr 06, 2009
phoenix chi
  • 389 Answers
SOURCE: phone shuts off and doesnt load all the way when you turn it on
the phone has multiple problems already, it has a software issue, you need to have the phone evaluated by a technician.
Posted on Jul 07, 2009
  • 846 Answers
SOURCE: My iphone 3gs won't turn on. If i plug it into
Sounds like you have at least a broken battery. Apple should give you a replacement. If you're out warranty, you can try to open it and replace battery. If that fails you need a new logic board. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
Posted on Jun 09, 2010
My Samsung galaxy 3 tablet won't charge or turn on.it was working just fine and now it isn't.please help
Try pressing and holding the power button for at least 10 seconds. This is a soft restart that can sometimes get the Tab to start. If that does not work, try holding it for 30 or even 60 seconds just to be certain. Try another micro USB cable if you have one. Cables can go bad suddenly. Try another charger. Even a standard computer USB port will charge even a higher power device like a Tab. The charge indicator might not come on, but it is trickle charging. It just takes longer. If you use a computer port or other low power source I would leave it plugged in at least 6 hours or so before trying to turn it on. If none of these work contact Samsung. Their support site has some troubleshooting capabilities and online support chat and even telephone support. It could be a little more convenient; they kind of force you to go through the steps, but I have always considered there support pretty decent. If you have not done so already, it is a good idea to set up an account and register your device on the Samsung website. Once you do there will be links for Ask a Question, Downloads, etc. You will need your exact model number which will be something like SM-T3100GNYXAR. I believe this is printed on the box label. If that is not handy it is on the back of the device in letters so tiny you will need good light and a magnifying glass!
Dec 07, 2014 | Samsung Galaxy Tab Tablet PC
Battery won't hold charge
It most likely needs a new battery, but you could try giving the battery a full charge first:
1. Power off the laptop and disconnect the power adapter.
2. Re-seat the battery (remove/reinsert)
3. Reconnect the power adapter and let it charge overnight. (6 hr+)
4. Disconnect the power adapter.
5. Power on the laptop (run under battery power only)
If it doesn't boot up and shuts down immediately, it's probably time to see about a replacement battery.
2.
Jan 11, 2013 | Samsung Q430 Laptop
Samsung s2 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 10, 2012 | Cell Phones
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Oct 25, 2012 | Sony Dvp-Fx740dtb Portable Dvd Player Sony
2012 VW Jetta TDI battery won't hold charge and car only clicks and won't start
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
Oct 09, 2012 | 2012 Volkswagen Jetta TDI Sedan 2.0L...
The car was running fine one day then the next day it would not start. We tried jumping it thinking the battery might be dead and it still would niot start. The car has power until we take the jumper...
Sounds like you have a toasted battery or alternator. Have you performed a load test on the battery? Have you tried to charge the battery? First remove the battery and charge it externally from the vehicle. If the battery won't hold a charge, or won't hold a charge of 12 volts, replace it. Once you have the vehicle started, test the operation of the alternator. It should be putting out at least 13 volts back to the battery to keep it charged - if it is putting less than 13 volts or more than 16 volts, replace the alternator.
Nov 01, 2011 | 2005 Chevrolet Malibu
My laptop is completely dead
Does the power cord not work? Did your laptop battery completely die and won't hold a charge? Anything happen to it recently like hardware/memory installation or did it get dropped? No power outages or lightening strikes?
Sep 08, 2011 | Acer Aspire 5050 5430 Laptop
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
