Primary master lock
My Lenovo govt lap B460e bios and Hdd Password locked please help (Primary Master St9320325AS Lock)
  • 6 Answers
SOURCE: need to bypass primary master HDD user password
The solution is to go to BIOS and u can enable and disable the HDD password query item. U can disable it and u can run ur computer again.
Posted on Apr 22, 2008
kikoksky
  • 119 Answers
the only solution is for you to call the acer tech support and they can generate a password for you to gain access to your hard drive and bios.
visit: http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Posted on Jun 13, 2008
tat4u
  • 520 Answers
send me ur email and I'll give you link for software to remove all passwords in bios or windows
Posted on Jan 26, 2009
  • 82 Answers
SOURCE: primary master lock
you try to reset your baios setting
Posted on Aug 31, 2009
rahimhd
  • 31 Answers
This site can help you with your hdd password / bios password problem
http://bit.ly/a0n3IS
or
http://www.acersnoop.co.cc
Search around and you will see that this is the cheapest one!
Posted on Feb 23, 2010
Aspire one laptop I turn acer on and screen shows Harddisk Primary Master ST9160310AS lock
All solutions point to having to contact the drive manufacturer or laptop manufacturer. There is good explanation in the Tom's Hardware thread at the end, about a 'master password' ...
4.June.2014
Hard disk security primary master lock
harddisk security primary master lock
Jun 04, 2015 | Acer Aspire One D150-1587 Netbook
I have a aspire one Acer and when I turn it on it says in a blue box, Harddisk Security and under it says Primary Master Hitachi HTS543216L9SLock. What can I do to restore it?
The drive is locked by a BIOS level Hard drive password. You can either contact Acer about a master password or replace the HDD since the password data is stored on the drive itself
http://www.fixya.com/support/r3894261-remove_bios_or_hdd_password_from_acer
Aug 13, 2011 | Acer Computers & Internet
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
My friend got me a lenovo notebook s10-2.but as I press the start butten it shows primary master lock ST9160314AS
The previous owner of the Lenovo put a "password" onto the disk-drive, to "lock-out" all other persons, including a THIEF. Ask your friend for the password.
Or, remove the disk-drive, and buy a replacement disk-drive, and re-install Windows.
Dec 30, 2010 | Computers & Internet
After boot, appears ENTER PRIMARY MASTER HDD USER Password i need the password @ solution to boot up my lappy... thanks
How Do I Change the Primary Master HDD User Password?
Prior to loading an operating system, your computer will first execute the BIOS program. The BIOS has an extra password feature, called the hard disk drive (HDD) user password, that can't be bypassed and provides a layer of defense to keep your data secure. To change an existing HDD user password you will have to load the BIOS menu, which is only accessible during the computer's operating system reboot procedure.
Instructions
1. Close any windows that are currently open on your computer. Eject any discs inserted into the optical drive and disconnect any peripheral USB devices.
2. Open the "Start" menu and select "Shut Down." Turn on your computer once the operating system finishes shutting down.
3. Press the key your computer uses to load the BIOS menu. For example, with Dell computers tap "F2" when the "Press F2 for Setup" option appears. Press the "Access IBM" key on IBM laptops or "F10" on HP desktops.
4. Navigate to the BIOS tab that contains the HDD password option, which will usually be the "Security" tab. Some computer manufactures instead include the password option in the "Advanced" tab.
5. Scroll down to the option labeled either "User Password" or "BIOS lock" and hit "Enter." Type the current master HDD user password when the prompt appears and press "Enter."
6. Input a new HDD user password and hit "Enter" again. Navigate to the BIOS tab labeled "Exit" or something similar.
7. Move over to the "Save and Exit" entry and press "Enter." Select "Yes" and tap "Enter."
Nov 15, 2010 | Acer Aspire 5610 Notebook
HDD primary master password
try reseting it through your bios, if your lucky there will be a way, if not, get a new harddrive
Jun 14, 2009 | Acer Aspire 3680 PC Notebook
Need to bypass primary master HDD user password
Jan 26, 2009 | Dell Inspiron 2650 Notebook
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
call the acer tech support or go on line a to www.acer.com and they should be able to get you need best regards mike
Aug 11, 2008 | Acer Aspire 5610-4648 Notebook
Jun 13, 2008 | Acer Aspire 5100-5022 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
