Av-733 megapro amp.
No sound or output at the right channel.
3 Suggested Answers
SOURCE: no right channel output after fuse blow out
Sounds like the power transistor(s) on that channel burned out. Needs service.
Posted on May 04, 2009
  • 256 Answers
SOURCE: Right outputs are not working
The right side output transisters are probally fried, End if you hook up both speakers to the left A&B channel you will do worse damage to it buy over loading it, Over it,s (OHM) Capacity, That mostly causes them to over heat end go up in smoke,
Posted on Dec 06, 2012
Rowe r92 sound problem
Moving the wire indicates the speakers are OK. Try reversing the 3 pin plug from the cartridge. If the problem stays on the same channel, it is probably a preamp board issue. If the problem switches channels, you have a bad wire to the cartridge or a bad cartridge.
Nov 16, 2011 | Audio Players & Recorders
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
Sony Bravia 40'' LCD 240Hz TV can't get video signal from DVD
Are you absolutely sure you have it wired up right? Are the Cable RIGHT wires color to color, is the "Correct Input" selected? Remember you do NOT use "Channels" but an AV, AUX, or External.input. Most DVD etc, use AV, IE: Yellow, (Video), Red, (Audio), White (Audio) for the OUT connections. These go color to color at TV end. And uses 3 Cables. The "Other" type of Output/Input is Component Video. This is ALL Video, Red, Blue, Green, these go color to color as well. BUT you MUST also send the Sound, Via the AV, IE: The Red & White, AV, Audio IN/OUT connections, So you in this case would have 5 cables/connections in all.
Feb 13, 2010 | Televison & Video
I would like to know how to connect my Bose 901 to my Yamaha RX-V765 AV Receiver.
Ahhh, the good ole Bose 901. (I like those)... And you want to connect them to the Yamaha RX-V765 AV receiver. That should be a piece of cake. I assume you only have two Bose 901 cabinets. If so, you simply need to connect one end of your speaker wires to the terminals found on the 901 cabinets, and the other end of the speaker wires need to go to the Front Left and Front Right speaker outputs of the RX-V765. The RX-V765 is a 7 channel surround receiver. Weather you run it as a 7 channel theatre or as a more classic 2 speaker configuration, you will want to run the 901 cabs from the Front L and Front R speaker outputs, unless for some reason you want to specifically use them for any of the surround channels in which case it will not harm anything if you use them for surrounds - it's just that if you're simply wanting to use them as your principal speakers, you want Front L and Front R.
So connect them as I explained, power the receiver up, put on your favorite CD and enjoy!
Oct 24, 2009 | Audio Players & Recorders
Connecting Bose 901 series iv to Harman Kardon AVR 254
Most HK av receivers have pre amp out,power amp in with metal jumpers connecting them for the main or front channels. that would be the best place to hook up the EQ on a AV receiver. If your receiver doesn't have pre out, power in jacks , you can use tape monitor .record out playback in. The tape monitor option is best for stereo use , as the active EQ will charge all speakers in tape mode, possibly damaging other speakers.I run my 901 s with a seperate pre-amp,power-amp hooked up to my Denon AV receiver that way i can run in surround w/standard speakers
Jan 06, 2009 | Bose 901 VI Main / Stereo Speaker
How do I connect my bose 901 active equalizer to a onkyo tx-sr506
AV receivers are notoriously incompatable for Bose 901s. The problem is the EQ charges the entire system and could damage the surround processor. Some higher end AV receivers, including some of the newer Onkyo models have pre out power in inputs on main or all seven channels.which you could install your EQ directly between pre amp & power amp without damaging processor. You can also add a two-channel amplifier to the pre out jacks front channels and use your recever's remote to control volume.
Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
POWER SURGE
sounds like DC on that output.
needs service possibly fried all the output transistors on that channel
Jul 30, 2008 | Xantech PA1235X Amplifier
No right channel output
Feed the amp with the left channel preamp to the right channel input on amp and check output. If you get output from amp then pre amp nedds to be checked out if still no output then amp is suspect. Randy
Feb 16, 2007 | Bryston BP-25 Amplifier
129 people viewed this question
 Grubhead
Grubhead
