Question about Car Audio & Video
Setting time Need to set time on stereo
  • 54 Answers
Hold source button until off. Then use function button to get into menu options.
Posted on Oct 20, 2013
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Car Audio & ... Master
  • 102,366 Answers
Could you tell us the make and model of the stereo?
Posted on Apr 29, 2013
Setting clock in 2003 cavalier stock stereo
On the bottom of your stereo front there are two arrow keys. One is for hours(L) and the other(R) is minutes. Turn stereo off and press each one until you get the time you want.
Mar 12, 2014 | 2003 Chevrolet Cavalier
I connect the acc wire to 12 volt and stereo stays on all the time
The accessory wire is suppose to be hooked up to your ignition wire and not a constant 12 volt power source. Hooking it up to your ignition wire will only give the stereo power when your key is in the accessory position or in the running position. The constant power source that you mostly connected to is meant for the memory wire on your stereo which will allows it to save your setting when you turn the vehicle off and your stereo kicks off. Otherwise you will end up setting the clock and adjusting your EQ every time you turn it on.
Feb 22, 2014 | 2004 Pontiac Sunfire
Resetting clock on truck stereo
The Kenwood KDC-MP335 is an aftermarket car radio that's available for many cars and trucks. The radio unit comes with a built-in digital clock. If your clock is showing the wrong time, all you need to do is enter the radio's clock-setting mode to correct the time and set the clock.------------------------------------------------------------------------
vas 5054a v19
Nov 28, 2012 | Cars & Trucks
Stereo without sub woofer how this setting
i have -VSX-D2011 when i want to stereo mode the sub woofer is automatic
play in stereo mode and disturb
i check all setting and much time waste on manual instruction
Stereo mode play only two front speakers if any one have knowledge about setting please help with advance thanks
Jun 26, 2012 | Pioneer VSX-D2011 Receiver
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
Need help setting time on jvc kd-sx770
turn off the stereo then ull see the time only on ur set then u can set up!
Mar 14, 2010 | JVC KD-SX770 CD Player
Need to set clock
1) Press the center of the multi-control button (big round knob) once to display the settings mode which appears on the digital display of the stereo unit.
2) Turn the multi-control to until the display shows clock settings.
3) Press the control ONCE to enter this menu.
4) The display wish show the 'Hours' flashing - turn the control to adjust this setting to the correct hour and press the control once to select.
5) The "Minutes" will not be flashing - turn the control to adjust this setting to the correct minute (time) and press the control once to select.
6) Locate the "band/esc" button on the bottom left corner of the stereo face and press once to select and exit the settings.
The clock should now be set. NOTE: There are a LOT of different models of Pioneer car stereos and they will not all have the same menus. The above steps should work on the newer systems.
Sep 05, 2009 | Pioneer Car Audio & Video
Time setting
set time on the sony cdx-ra700 stereo
Jan 13, 2008 | Sony CDX-RA700 CD Player
JVC KD-G430 problem setting the time
You can download the manual from the link below: http://books.jvcservice.com/booklist.asp?Model=KD-G430 The time setting is on page 13. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 21, 2007 | JVC KD-G430 CD Player
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
