Question about Sanei N78 7 Inch Android 4.0 Tablet PC Built in 3G Qualcomm Dual Core
My tablet sanei N78 wont charge? - Sanei N78 7 Inch Android 4.0 Tablet PC Built in 3G Qualcomm Dual Core
Problem with volume control. Keep recurring without pressing and makes the system unresponsive
How old is this? If under warranty or less than a year then return it for replacement. If older than that I suggest you get it looked at by a technician.
Jul 09, 2015 | Sanei N78 7 Inch Android 4.0 Tablet PC...
My tablet n78 is shut off .it wont charge or show any sign....
Test your charger with a multimeter or take it to a Battery+ store to see if it still provides the proper charge (they test it for free). If your charger is good, it might be the internal battery of the tablet or the main board.
Dec 08, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
Sanei tablet not switching on
It's normal for a device to heat up during use and charging. As long as it's not too hot to hold, there isn't a problem. If it is hot enough to burn you I'd replace the battery
Dec 08, 2013 | Sanei N80 8GB Allwinner A10 Cortex-A8...
Sanei tablet 3it is not running on laptop pc hp
To connect up a tablet with a laptop you need to connect them with a USB cable.
On plugging in the cable with the tablet powered up, you should see two things.
1. A question on the tablet as to whether you want to use memory disc mode or diagnostic(ADB) mode. Choose Memory disc mode.
2. You should see on the PC laptop it recognise that an external device is connected, it may recognise it as a phone or a memory drive.
If neither of these things is happening it is probably the cable at fault.
The tablet should then start providing the pc laptop with the drivers it requires to be recognised. If this does not happen, then the fault is with the tablet and you have to consult your supplier.
You should end up with at least one memory drive which you can browse through with the PC's file manager. The data will be on the tablet.
Nov 30, 2013 | Tablets & eReaders
Tablet wont turn on
Try to charge it by the original adapter as the PC USB output is not power full enough to supply charging for it
Apr 29, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
How do i do factory reset on sanei n91 tablet
How do i do factory reset on my daughters sanei n91 tablet she lost pattern lock and had tablet in flight mode so cant recover from email holding power and volume does nothing for reset.HELP
Mar 07, 2013 | Tablets & eReaders
Sanei n10 manual english
i have sanei n10 tablet and i lost the password and google accaunt what can i do ?
Jan 21, 2013 | Easy SANEI N10 Android 4.0 Tablet PC 10.1...
Sanei N78 7 Inch Android 4.0 Tablet PC Built in 3G Qualcomm Dual Core Logo
235 people viewed this question
Top Sanei Tablets & eReaders Experts
Are you a Sanei Tablet and eReader Expert? Answer questions, earn points and help others
