Question about Dryers
Casablanca Zephyr 1002T Ceiling Fan - light stopped working
For my Casablanca Zephyr 1002T ceiling fan (from about 1989), the fan works fine, but the light switch just stopped working. When I try to turn it on, I hear some beeps (sort of like the beeps from when I turn the fan off) but nothing happens. I also hear a slight clicking sound coming from the fan while it is beeping. Anyone know what the problem is and how I can fix it?
  • David Apr 30, 2013
    Later that evening, I went to show my wife what was wrong. I told her what it would do, and then I pressed the button...and the light came on just like it was supposed to. Anyone know what is going on?
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
  • 1810 Answers
SOURCE: Hampton Bay Ceiling fan will not come on
greetings home electrition
it's most likely the switch has failed
but on rare ocation the switch comes un wired
also somtimes the switches stick they stick in the on or off position
try pulling the chain and listen for the usual click if it aint there then the switch is pooch if click is there start look at the wires failing that replace the switch
there cheep 2-5.00
Posted on Jul 29, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
  • 101 Answers
SOURCE: my ceiling light and stopped working
Hi there,  First of all, can you tell if there's power going to the light? Lets first make sure that it's not a power problem. You can check your circuit breaker in your main electrical panel. Now, when checking this - leave your light switch in the ON position. So when you're checking the circuit breakers, you can see from afar if the light/fan comes on. Now, you can also have a light switch problem too. Turn the switch on and off; and wiggle the toggle (lever) on the switch to make sure its tight. Next, get up on a ladder and make sure that your switches on the light itself are on the ON position. It most likely is, but you're just ruling things out. So, if you think there's power getting to the light - then turn the wall switch OFF. You can also turn off the circuit breaker as added protection. You would then need to take off the bottom of the light/fan to get to the wiring connections. If you have a little inductance tester, which when you put it up against the wires - a light, a beep, or both come on to let you know there's power. These little testers are invaluable. There very inexpensive, and they can save you plenty of headaches. If you can buy or borrow one, you would open the bottom of the light/fan - and make sure all your connections are tight and secure. I come across a lot of shabby splices were the wires aren't all the way in (secure) when its installed, and eventually with the vibration of the fan motor - the wires will work themselves loose. After checking the connections, clear yourself from the light/fan and turn the wall switch ON. Then go back up the ladder and wave your tester up against the wires to see if you have any power at the light. If you do, then you most likely have a switching problem at the light/fan.  To confirm this, you would turn OFF the wall switch again. Go back up the ladder and wave your tester to double check that there's NO power. Your next step would be to bypass the switch on the light/fan. You can do this by removing the switch and splicing (joining) the two wires together...or, you can locate each (only two) wire coming from the switch - and then splice (join) these two wires together. Now that you've bypassed this light/fan switch - get down from the ladder and turn ON the wall switch. If this is the problem, then the light/fan should work ALL together when your wall switch is in the ON position. If it works, then you'll have take that switch with you to your local Home Depot, Lowes, or hardware store to get this part. Its easier to take the switch with you and show the clerk at the store the part you need. They are common parts, so you should have no problem. Lets stop here for now. I believe you should find the problem by now. If not, please contact me again - and let me know what you have done, and what everything you did resulted in. I don't believe you'll go this far, but if so - then we'll proceed from there. Good Luck, and remember to turn the power OFF when you're working on the light/fan - and make sure your connections are secure when rewiring your connections back up. And then put everything back in order of how you took them off. I hope this works for you! Jim
Posted on May 10, 2010
SOURCE: I have a Casablanca Intelli touch ceiling fan.
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
Posted on Sep 01, 2010
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    Casablanca Trident ceiling fan issue - light suddenly stopped working - replaced bulb to no avail - fan works fine otherwise...ideas?
    Is it powered from the same breaker as the fan, check the breaker, if so check the connections. Most likely if its a pull chain switch the switch is bad,,,,, it's common..
    May 29, 2014 | Dryers
    I have a Casablanca "trident"
    Hello Duke,
    I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
    Hope this helps.
    Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
    My inteli-touch casablanca fan won't turn on at all (light or fan). Today there was an interruption of electrical power to the house and now the fan won't work. I know there is a way to "reset"...
    I have had 3 casablanca intellitouch fans stop working. All 3 had the same problem. The 1000uf/35vdc capacitor failed. Replaced with 1000uf/50VDC cap from Radio Shack. No problems since.
    Nov 09, 2010 | Casablanca Fan 3245T Ceiling
    Remote stopped working, fan and light do not
    click the reset and turn off the fuse box and then turn on
    Feb 15, 2010 | Casablanca Fan 3245T Ceiling
    Ceiling fan light flecker
    Grinding indicates failed bearings. This is causing excess load in the motor and that is causing the flickering. This is not a user repair and would like cost around $130.00 for labor and bearing assuming you find a shop willing to do it. Most fans have pressed bearings and are very cheap.
    Sep 02, 2017 | Casablanca Fan Stealth 3211T Ceiling
    Casablanca Ceiling Fan
    I've never heard of the light and reverse buttons being reversed. Normally It's the fan and light thats swapped (but your aware of that already). I would try a working w-32 from one of the other fans. There's also a shop called Fan Man Lighting in Minnesota who has a guy named Jason who has been fixing fans for over 20 years, He helped me with my Casa problems. Their website is www.FanManLighting.com Hope this helps.
    Nov 01, 2008 | Casablanca Fan 3245T Ceiling
    Casablance Ceiling Fan Trouble
    itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
    Jul 16, 2008 | Casablanca Fan 3245T Ceiling
    Ceiling Fan broken
    clean and grease the fan check the black cap to see if it is not fauly if it is replace it.if that does not work the ammeture is faulty time to buy a new fan good luck
    Apr 27, 2007 | Casablanca Fan Bel Air 3811T Ceiling
    Dryers Logo
    143 people viewed this question
    Top Dryers Experts
