Question about Measuring Tools & Sensors
Spare parts- broken vane off wind sensor Do I have to buy complete unit or just the part
  • 16,589 Answers
Who makes it?
Posted on May 06, 2013
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
Wind sensor doesn't work
Test all wires for continuity. 90.8 % of problems are caused by faulty wiring.
Aug 13, 2017 | dr. Tech WA-1080PC-T Solar Wireless Home...
Hi,two of the three cups on the wind sensor have broken off and i am now looking to see if the piece with the cups can be replace. will the unit record with one cup?thanksronald rosandichrrosandich1
Hello Ronald
No it won't accurately record Wind Speed because it is out of balance and lacking two parts of its motive power.
Here is a link to a new wind vane. Or you could superglue the bowl of a plastic spoon to it. Use Superglue Gel.
Please don't post personal contact details to FIXYA. We have 7 million visitors a year and some of them will try and scam you or phone you are 3:00am for a chat!
Andrew - Fixya Moderator
tx 23u wind sensor for la crosse 915 mhz weather stations eBay
lacrosse ws 2813u it wind sensor parts Google Search
Jan 21, 2018 | Lacrosse La Crosse WS-2813U-IT Pro...
St60 Wind Vane Ducer E22078: Where is the best place to get a replacement paddl...
Go on www.raymarine.com and search for a dealer in your area and they will be able to help you. The wind service kit sells for less than $30.
May 17, 2010 | Raymarine St60 Wind Vane Ducer E22078
Whre do i can buy a genuine bajaj spare parts
i was also facing problem with availability of genuine bajaj spares for my Bajaj-Caliber motor cycle.
But i had to import it from india.
dealer name H.M AUTOMOTIVES Pte LTD www.hmcalcutta.freewebspace.com
Apr 09, 2010 | 2005 Bajaj Wind 125
The self-closing valve on our 13 year old ST60 speed transducer now only closes sometimes when the blank or impellor sensor is removed. We suspect that a spring is missing. We need a raymarine spare part...
Spring not available must buy housing and replace or if it is sleeved, buy housing and slide in new sleeve there are two different types, one has a removable sleeve with flapper
A long shot would be Raymarine tech support 800-539-5539
I can sell you the part 847-746-0100 technicalmarine.com
Feb 20, 2010 | Raymarine St60 Plus Package, Includes...
I was in a flood need to rebuild butterfly 3/8 air tool
Takes notes and pictures as this can be helpful. Most impacts will return to operating condition with a simple cleaning and lubrication.
1. Remove the body screws and disassemble the unit.
2. Clean all parts with ATF and a scrub brush where needed.
3. Reassemble the unit and test.
There are no complicated parts in this unit. The center "armature" of the unit is comprised of a solid cylinder with slots and fiber wind vanes. One side of the vanes is rounded and the other (outer) is flat. If you are having problems with it rotating this is more than likely where the cause will be found.
Jan 20, 2010 | Air Tools & Compressors
I have a E22078 Wind Vane. How do I check the wiring continuity at the cockpit without climbing the mast? Can I use a multimeter to read impedance up to the wind instrument?
You can read the motor/generator windings with a volt ohm meater. Is it dc or ac? You should be able to read some voltage as long as it is turning? If it is a dc generator it will read dc voltage at the slightest of wind speed. If it is an ac generator it may have to be above 5 mph to get a reading. No reading could mean a broken wire.
Sep 10, 2009 | Raymarine St60 Wind Vane Ducer E22078
Air outlet vanes not moving
they usually snap together. they are plastic, its possible it became unhinged or broke.
Aug 19, 2009 | NewAir ACP-1300H Air Conditioner
Raymarine ST50
http://www.defender.com/product.jsp?path=-1|344|295761|301233|320702|746011&id=823240
Oct 19, 2008 | Raymarine ST60 A22012-P GPS Receiver
Measuring Tools & Sensors Logo
198 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
