Question about Hardware & Accessories
Utilitech Model 0079356 power cord - Hardware & Accessories
Utilitech pump model KLHO75 manual
Lowe's has the manual for the Utilitech KLH075 0.75 HP submersible pump on the product site: http://www.lowes.com/pd_240035-84862-KLH075_0__?productId=3880627 . Click on the Info & Guides tab. The direct link to the guide is http://pdf.lowes.com/installationguides/717301122392_install.pdf . This is labeled an installation manual. The operating instructions start on page 6.
I hope this helps.
Mar 24, 2016 | Plumbing
Only one yearold;turn on,or plug in kicks breaker
Roger, DO NOT USE. Return to place of purchase, or cut cord and discard.
Apr 24, 2015 | Utilitech 0.33-HP Thermoplastic...
We have a utilitech sump pump model #0313508. I am looking for the plastic, or metal standoff through which the float operates.
You might have to make your own. Think of stainless steel rod etc. Utilitech is not a universal brand. Parts are not available and the whole unit is expensive. Grainger does not have anything and it appears that the exclusive provider is lowes.
Sep 20, 2014 | Electrical Supplies
Need manual for utilitech 43467
You might be able to obtain this directly from the supplier
Jan 15, 2013 | Utilitech 1/2 HP Convertible Jet Pump...
Utilitech #73189 installation
Utilitec 73189 is ordinary 120Volt fluorescent light.
Where are you installing this light?
Are you wanting to hardwire this light so it connects directly to a switch?
Does the light have a plug-in cord?
Or do you want instructions how to wire a plug-in cord to the light? And then install small rotary line switch on the cord.
I would buy a cheap extension cord that already has ends. And buy rotary line switch that fits the cord.
Then cut off one end of extension cord so it will plug into outlet.
Install the line switch onto the cord.
Connect the cut-end of extension cord to light fixture, black-to-black white-to-white-green-to-green.
Add a comment and include more detail.
Aug 20, 2012 | Hardware & Accessories
Instuctions for utilitech timer 0050024
Copy following link for possible Utilitec manuals:
http://waterheatertimer.org/Program-wire-Utilitech-LW60419.html
Dec 19, 2011 | Hardware & Accessories
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
