Question about Microwave Ovens
How do I fix electrical problems on the microwave
It would be better if you call an electrician for this purpose as he would better know about the problem or you can read manual of this oven and fix if it is possible. I hope it get fixed soon
Posted on Apr 29, 2013
Model 8006262000
I assume your oven is electric and not gas? If so, consider replacing the fuses on the oven, which are located in the back. THese fuses are pretty cheap, just ask around at the hardware store. This should fix your problem.
Dec 05, 2013 | General Electric GE 27"" Built-In Double...
F3 code
An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
On many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Aug 10, 2011 | General Electric Microwave Oven
We have a Hotpoint RVM1435WJ01 above the range microwave. We lost our electricity one day due to an outside electric wire splitting - when the electric company fixed the wire, the power came back to...
A mains surge may have taken out the fuse. To find the fuse, remove it from the mains, remove the outer cover and follow where the power cable enters the case. There will be a PCBoard with a fuse on it.
Always replace the fuse with one of exactly the same type and value!
Mar 21, 2011 | Hotpoint RVM1435 Microwave Oven
Get F3 warning on panel. where are the codes located so i can see what the problem is, thank you JOHN BOMSA
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Hope this helps.
Feb 01, 2011 | General Electric PEB1590SMSS Stainless...
I have a GE Spacemaker Microwave Model JVM1540. The vent fan will not shut off after the microwave shuts off. I have to unplug it in order to get it to shut off. Any solutions to this problem. I have...
Rlfoster.
It is not a filter problem.. but a relay (electrical)
There is a electronic board that may becomming defective.
If there was a spike in the electrical it could have erase the memory,
You or I cannot reprogram but only replace the board. I don't the price of that board
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave won't heat and makes a bad noise
thereis internal problem but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
Dec 29, 2009 | General Electric Microwave Oven
I have the LG 1433ss microwave, my turntable stops turning. Where do I find an expert in canada to help me fix it? Can I fix it myself?
I suggest you go to RepairClinic.com and use their troubleshooter. If you can use a screw driver, you can probably fis this problem. It might be as simple as checking the electric plug on the motor.
I hope this helps you.
a
Sep 25, 2009 | LG Over-the-Range Microwave
GE microwv-doesn't heat, strong electrical smell, all else ok
The most common problem would be your magnetron. Check your purchase date, magnetron's usually have a five year warranty. Not a part I recomend trying to fix yourself (high voltage ).
Mar 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave totally shuts off by itself
My microwave is under warranty. I have this problem before and it was "fixed" one month ago by replacing a thermostat. This repaire is under warranty for 90 days.
I will have a service man to look into this problem.
Thanks MK
Jun 29, 2008 | Jenn-Air JMV8196 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
