Question about Briggs & Stratton Garden
When you start engine white smoke pours out and oil is blowing out 2 feet out of muffler.
  • Briggs & Str... Master
  • 7,482 Answers
Hi michelley636
Check your oil level, it sounds like it is too much oil in the crankcase causing it to burn in the combustion chamber
Bud
Posted on May 01, 2013
  • 109 Answers
SOURCE: lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Posted on Apr 21, 2009
  • 61 Answers
SOURCE: white smoke
White smoke is most likely cause there is to much in the engine.. Only takes about half quart.. Clean with degreaser and garden hose on the outside..
Posted on Jul 04, 2009
  • 130 Answers
SOURCE: Oil is leaking from the muffler and white smoke is coming out.
this is more severe.if you are not a small engine person 3 things get a book on mower or take to shop or get a new mower.
not trying to be funny but if you dont know its going to be hard for you to fix the valve guides are bad need to replace will take speical tools to fix.sorry
Posted on Jul 22, 2009
moretons
  • 155 Answers
SOURCE: My cub let out a big ploom of white smoke and shut off.
This is caused by two things low oil level and overheating, The oil also has a cooling agent in it so if it was run low the engine would not get lubrication and overheat possibly causing the conrod to break if you say its only 10 hrs old i would be talking to the dealer you purcased it from or the engine manufacturer. its unusual for an engine with very little hours on it.
Posted on Jul 27, 2009
  • 93 Answers
SOURCE: white smoke! Power Devil petrol lawnmower
Clean Carb and adjust
Posted on Sep 15, 2009
I was mowing Yest and White smoke started pouring out the Front Could that be bad gas or what
no its not gas. it could be a few things. look on the front of engine and see if it is leaking oil on the muffler. could be rings are bad. could be a valve has stuck. either way it sound like it is a project. when white smoke comes out exhaust it is usually engine failure.
May 12, 2016 | Garden
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
I have a brand new masport mower, too much oil was put in and it was blowing white smoke, dripped it up drained some out few days later start to mow it'll mow for a few mins the blow alot of white...
make sure oil is at the correct level , remove exhaust muffler drain all oil if any, reinstall and run it until smoke clears , it should not take too long . Make sure engine is cool when working on any component
Feb 25, 2013 | Garden
I have a 1985 xr250r and it blows a **** load of white smoke out the muffler it has recently had new oil put in top end rebuild not long ago and new spark plug what should I do to help fix
Hi, Jordan your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the links below. Good luck and have a nice day.
CR125 white smoke and oil from exhaust
XR 400 Blowing White smoke
Honda XR250R Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda XR250R Owner Manual
Apr 01, 2012 | 1985 Honda XR 250 R
I changed the oil and white smoke poured out of the exhaust. Also there was oil spewing all over.
Depending on if you laid the engine over on its' side, there could have been oil in the muffler. It may take some time to "burn" this off. It will also come from the muffler. Given enough time the oil will get hot and smoke off of the muffler. Then it will no longer smoke.
I hope this answers your question.
Apr 03, 2011 | Garden
I have a Toro Zmaster mower The engine is a FH580V KAI19. It was running fine. Parked the mower last night, tried to start it today and oil is coming out of the OHV cover and blowing by through the...
you could have a broken piston ring. check the oil level. if it is ok or low and still smokes or hard to start then you may have to overhaul the engine. let me know what you find.
Mar 13, 2011 | kawasaki Garden
2004 Excursion 6.0 diesel blows intermitent white smoke
I don't drive a Ford but I drive an International and white smoke on start up means the engine is too cold to properly burn the fuel. Your black oil or soot is unburnt fuel. You should look at your engine's preheat system for a malfunction.
Jul 13, 2009 | 2006 Ford F-250 Super Duty
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Muffler blowing white smoke
take it back the engine has a blown head gasket or cracked head all cost over 1200 to fix
Mar 15, 2009 | 1997 Dodge Caravan
Garden Logo
129 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
