6 amp power board fuse blow when power button pressed.
As soon as I press the power button the 6amp fuse on the power board will blow. I have replaced it once and it keeps happening as soon as the power button is pressed. Any ideas how to figure out what to replace (other than the whole thing).
  • 8 more comments
  • Brian A Apr 29, 2013
    Thanks for the response. It is a denon AVR-800. I took a look inside and saw no visible signs of damage other than the fuse. Origionaly I thought the main trasformer may have gone bad as this fuse seems to be between the wall power cord and the leads to the transformer. There are two other fuses closer to the heat sink that are undamaged. To work on this I currently only have a good soldering iron. Could you tell me what tools I would need to properly test and replace what might be broken? I have read that all transistors in parallel with the shorted one must be replaced. Could you tell me what trasistors I should get and where is a good source? Thanks
    And if it helps only the headphones were plugged in when it blew the first time and nothing was plugged in the second. I believe I also had it set to headphone only the first time. With this setting nothing is output to the speakers.
  • Steve K Apr 30, 2013
    You would have to have a multimeter in order to check the transistors and see which ones are bad. You don't usually have to change all the transistors in a channel unless there are all smoked. Look at the small reisitors near the output transistors and see if any of them look burnt. This will give you a clue as to what channel is bad.
  • Brian A Apr 30, 2013
    I dug a little deeper into it and found something. On the top level of chips that are screwed into the heat sink there are two chips both with five pins. When I turned the circut board over I could see that both of them had some traces that looked schorched. I wish I could post a picture but I am pretty sure this is the problem area. Now can I just replace those chips? Does this schorching ruin the board? It looks like maybe some the the traced may have melted together. Are these five pin chips transistors (I guess I can look that one up)? Thanks
    The numbers on the chips are (SK 18752 3805) on one and (SK 18752 3611) on the other. I think I see solder or that brown burn mark touching two traces. Even without the short does this brown burn mark ruin the trace and therefore the whole board?
    are you sure the brown that you're seeing is not just leftover solder flux?
  • Brian A May 01, 2013
    Here is what I saw. I am pretty sure this is what fried. Is the boad ruined too?
  • Steve K May 03, 2013
    looks like excess solder flux. I doubt if that is the area of you problem
  • Brian A May 04, 2013
    OK, I looked a little further and found this. This crack is definitely not right. This left, center and right channel transistors seem to be in pairs. Would I need to replace the pair or just the cracked one? The pins are bent 90 degrees and soldered to the bottom of the board. Replacing will be tricky because if I don't get the bend exactly right the pins won't be positioned next to the board and also since it is on the board everything will have to come out to get at the bottom of the board. Is there a trick to replacing these?
  • Steve K May 06, 2013
    You always replace output transistor in pairs. You will also need to check for any open resistors in that channel. Sometimes you get lucky, and it's just the two outputs and the fuse.
    Genius:
  • Audio Player... Master
  • 1,054 Answers
That is usually caused by shorted output transistors. What brand/model do you have?
Posted on Apr 29, 2013
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: unit wont turn on
.Hi jepenny
The board you are looking at is the standby cct and power switching PCB. It sounds like that is working, so you have probably lost power to the transformer primary or the transformer is open circuit. Check for blown fuses and replace with exact same type and rating.
Be sure to unplug at the wall before touching any internals!!
If you can find no blown fuses, the power transformer may have failed. Good luck, get back to me here is you need any more advice. Thanks for using "FixYa"
regards
Graeme
Posted on Feb 18, 2008
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
  • 120 Answers
SOURCE: JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Posted on Jan 06, 2009
  • 5 Answers
SOURCE: sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Posted on Mar 19, 2009
Mr. Peter I changed fuse 6.3 amp 125v from f board 6amp 125v from radio shake. is that make any difference.
you need to put fuse 6.3 amp to 6amp with same 125v if fuse not match or it will give problem
May 30, 2014 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have a triton t100xr shower as soon I press the on switch the power keeps tripping off, please can you help?
Chances the trip switch is not high enough,as in it may need a higher amp than what has been installed.You should be able to check this out by looking at the fuse board.If memory serves me right it should be 40 amp.Check this out in the paperwork that came with the shower. If not contact Triton, they are most helpful & easy to deal with. Their number can be got on Triton site. Be VERY careful when touching any wiring either @ the fuse board or the shower.
Apr 24, 2014 | Home
What is the fuse or fuse code for a Panasonic CT-32HL43
Some advice here;
The fuse is in a snap in holder and marked on the board and fuse as (look and see) 6.3 A 125 vac= 6.3 amps at 125 volts (a 250 rated fuse will also be fine as it is just max voltage rating).
In this case what I have seen is do not use a generic fuse like from Radio Shack as it likely will blow instantly for no reason.
We discovered early on (shop where I work) that both Panasonic and Sony (use same fuses) had this issue.
Do not exceed the amp rating for any reason---if a compatible fuse blows instantly then a short exists---if fuse where power cord enters either just the fuse or a short at the input area of the set's power supply.
to reply or ask more press the "make a comment button" on this page.
Mar 25, 2012 | Panasonic Televison & Video
Accidently pushed a button and then the tv went fuzzy so i pushed standby but nothing worked, then i pressed power and it keeps clicking on and off and wont stay on
Check power supply board located on the Right bottom board,in the middle is a 6amp Fuse it could be blowed.
Located on the Left Hand side should be the Big Black ICs will have part number on them STK392-110 ,Bad STK ICs can cause this also.
Mats Electronic Parts 1-800-628-1118 they will have ICs ,ect...
Jul 20, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
After hitting the power button, the TV appears to power on, but absolutely NO screen: completely black.. Lamp? Or some kind of circuit board? Hitachi 57" rear projection 1080i purchased in 05
Check all of the pico fuses on the power supply board they will look like resisitors but are Fuses will be Green or Yellow Color, 5amp, 6amp ,7amp pico fuses
Jun 02, 2011 | Hitachi 57F500 57" Rear Projection...
If i put a 6.3A 250 Fuse in a receiver asking for 6.3A 125V will it damage the receiver
no it wont --in all likliehood your amp is shorted however ,and the fuse will blow again ..its rare that a 6amp fuse blows w/o an internal short causing it
Sep 03, 2010 | Audio Players & Recorders
Hitachi Plasma not getting power
What it sounds like is the fuse on your power board has blown, or the power board itself has gone bad. You will need to remove the back of the tv, and visually inspect the power board, also note any weird smells. You can also check the fuse at this time. If it is not your power board, please let me know while you have the back off as I can walk you through any further steps at that time.
Oct 27, 2009 | Hitachi 42HDS69 42 in. Plasma Television
ISymphony M110 blows fuse.
there is an 022 farad cap right under the f901 f 904 f907 f905 6amp rectifier on the main board if short will blow supply board fuse first before it blows the 4 amp fusses on the main board. replace as needed.
Jan 09, 2009 | MediaGear SongBank MP3 Player
Sony Triniton Fuse Blows
You will have to trouble shoot the board down to the component level I'm afraid. I would for sure pull out the transistors or the FETs to get a good reading on the parts.
Feb 10, 2008 | Televison & Video
I can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Jan 11, 2008 | Panasonic CT-36SX12 36" TV
251 people viewed this question
 Grubhead
Grubhead
