Question about Acer Extensa 5630-6806 Notebook
My acer extensa 5630 will not start
My laptop had its hard drive and ram removed and put back in. when the power button is pressed all the aplicable leds illuminate and the hard disk spis for about a second, but no BIOS load. I tryed with an external monior but nothing still. It is a work laptop so please help.
  • Andrew Pearce Apr 29, 2013
    hard disk and fan *spins but not optical drive like normal
    I just had to reseat the ram and the computer started. Thanks for your help
  • Acer Master
  • 32,281 Answers
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Apr 29, 2013
5 Suggested Answers
SOURCE: Acer Extensa 5630 not booting
seems you have two problems
the ribbon cable on the lcd may be loose,
or need replacing ,
also check the pin in the dc jack if it moves at all or need to wiggle the ac adapter,it could be bad jack, but first make sure the ac adapter end is not bad, as the hole in the end gets bigger , it may not be connecting right
Posted on Jul 21, 2009
benwabnick
  • 2404 Answers
SOURCE: Acer One 1542 series.Power on but not boot.
since you reseated the memory, the last two things I would do is remove the hard drive and dvd drive.
If you remove those and you can't get video then the motherboard is bad.
Posted on Aug 03, 2009
  • 2666 Answers
SOURCE: how to reboot acer extensa 5630 laptop
Put recovery disc in and while system is starting press F12 key repeatedly until boot menu appears then select boot from CD
Posted on Sep 17, 2009
Testimonial: "Thank you. Very helpful"
ruwidperd372
  • 279 Answers
SOURCE: Acer Extensa 5210 blank screen
re seat the memory cards, clean them if necessary with pencil eraser (the metal connector on mem card), if it won't work, you might need to replace them with the new ones
Posted on May 04, 2010
How do i clear passwords from acer extensa 5630ez laptop
For windows, press "start",choose "Run", input:"control userpasswords2", in new dialog, choose user and remove the
symbol hook.
http://www.ezbuybatteries.com/acer-extensa-5630-battery-replacement-16514.html
25305759-ro4juc232otbw4vvuq10f504-5-0.jpg 25305759-ro4juc232otbw4vvuq10f504-5-2.jpg
Dec 03, 2014 | Acer EXTENSA 5630EZ423G32MN COMPATIBLE...
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
My extensa 5630 could not power up. But some times when I press the power botton it start.
Remove the battery & try to gently wriggle the power adapter around in the power jack while try to boot it up. Does it start to power up and then shut off? If so, then your female power jack most likely needs to be re-soldered or replaced.
Mar 13, 2010 | Acer Extensa 5630-6806 Notebook
Hello!I would be very gratefull if you help me with the startup problem of my Acer Extensa 5630!Sometimes(recently very often)it just won't turn on.I red some complaints of other owners of the same...
Not at all, If your computer was closed normally, it will start normally.But if you closed it from the button without shutting down from the windows, it will not start normally the second time.
so, when you face such a problem, just remove the battery for 12 min. then start up using power cable, hold ESC for 10 sec (when you hear a beep) stop and close from the button then power up using your battery, it will start correctly.
Feb 01, 2010 | Acer Extensa 5630-6806 Notebook
How to replace Acer Aspire 5630 Hard Drive
The link below gives you the user manual. On the computer views is the base view which will show you the correct bay on the bottom of the computer. You will loosed the screws to that bay, remove the cover andl you will see the hard drive. Althought I have not removed this particular laptop hard drive, these drives usually pull up or back using a tab provided. The hard drive will probably have a cradle the actual drive is connected to. You will have to removed the old drive from this cradle and put the new drive back on the cradle exactly the way the old drive was attached,
I hope that this information helps and gives you a place to start solving your issue.
Brian
Jan 24, 2010 | Acer Aspire 5630 Notebook
I have an extensa 5420-5687. 1 day my laptop just
the power cord has shorted out you will need to buy a new one
If I have helped you please click the yes this was helpful button
Dec 03, 2009 | Acer Extensa 5420-5687 Notebook
Power supply flashes green and no lights on laptop
Remove battery pack, press and hold power button for 5 seconds, then put battery pack back in and restart pc. This should take care of it. A bad memory stick can cause problems like this as well.
Nov 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
How to reboot acer extensa 5630 laptop
Sep 17, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
My laptop wont turn on
when you hit the on button the green light go off after a while, i suggest you bring it to technician your laptop is shutting down as it about to open, its either the sensor is not working and making it to overheat or the power switch is loose, hope this help
Sep 17, 2009 | Acer Extensa 5630-6806 Notebook
I have acer 5630 i put bigger harddrive in but it won't let me put windows on it
Are you installing it properly from the CD.... need more information...
Does it see the Hard drive in the BIOS? Does it boot to the Windows CD? Have you created a partition properly?..
Need more information before anyone can fix this.
Sep 08, 2009 | Acer Extensa 5630-4933 Notebook
Acer Extensa 5630-6806 Notebook Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
