Question about Reebok Challenger 150 Treadmill with SpaceSaver Technology - Built-in
Belt will not move or incline
We just put this together and the belt won't move or base incline. Why would this happen
2 Suggested Answers
SOURCE: the belt won't move and the incline is stuck.
reebok 8000es incline keeps going up and down and will not stop or go into any other mode
Posted on Mar 02, 2010
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
Brush doesn't move
Your belt is broken and needs to be replaced. Turn this brush side up. Unscrew the cover plate and you will see where the belt goes. Pull out roller, put on new belt, put back together and there you go.
Oct 07, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
Proform 470 treadmill, belt won't run
see the video attached:
1) LUBE THE DECK BELT
2) LUBE THE ROLLERS BEARING
3) if this NOT has solution , you must test the a) motor y/o main motor board see the block diagram
God bless you
Jul 31, 2012 | Exercise & Fitness
Nordic Track X5 belt won't move
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn.
2) Lube the rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
I have a Cub Cadet zero turn RZT 50 that when I go up a steep incline and put the driving bars all the way forward it won't move. The back tires don't even spin. When it is on even ground it
being that each wheel has its own pump and motor the common connection is the belt it must be slipping and if its slipping without making a lot of noise look for oil being on the belt if so look for the leak the bottom of the engine crank seal is a common spot
Apr 25, 2012 | Garden
My treadmill belt doesn't move at all
Contact the seller for help or send it back if it's only a month old, it must be under warranty.
Jan 25, 2012 | FreeMotion Exercise & Fitness
I have a 42" Craftsman
HI IF YOUR BELT IS LOOSE THEN YES YOU NEED A NEW BELT
IT IS A V-BELT GROUND DRIVE-95 25
PART /160855
Sep 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hi, I would like to ask a few questions: 1. Does the Maxi Cosi Cabrio car seat fits only to the isofix base, or can it be installed to the mico base as well ? If it does, the only difference is that the...
Good Morning
The Maxi Cosi CabrioFix can be fitted without any base, using the 3 point seatbelt: With the EasyFix base, using IsoFix points or 3 point seatbelt: With the EasyBase and EasyBase 2 using the 3 point seatbelt. It cannot be used with the Mico carseat base as they are not designed to be used together. The Mico is available in US and does not meet UK standards: Likewise the CabrioFix does not meet US standards so they should never be used together.
If you don't know how to fit the carseat into your vehicle using the 3 point seatbelt please check your user manual, or download a replacement copy at www.maxi-cosi.com before use go to an authorised retailer to check it is correctly installed as this will affect the performance of the carseat.
Aug 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I washed my daughters graco car seat and now i havent a clue of how to put it back together and i need re assemble it fast please help
Proper installation of a car seat is imperative to protectan infant. Accidents do happen and assuring that the instructions forinstallation of the Graco Infant Restraint/Carrier are followed will increasethe chances of preventing injury or death as a result of an accident. Graco carseats are a popular choice among parents due the availability of products atcommon retail stores, affordability and user-friendly baby gear.Graco Car SeatInstallation
Step 1
Plan to secure the infant seat facing the rear inthe middle of the back seat. If a center position is not available, positionthe seat directly behind the driver's side seat. For safety reasons, therestraint should not be placed in a position where there is an air bag. Ensurethat the proper vehicle lap belt system is in place; manually adjusted lapbelts, automatic locking retractor lap belts and lap/shoulder belts withlocking latch plates are all considered safe for use with the Graco InfantCarrier/Restraint.Step 2
Remove the carrier from the Graco car seat baseby squeezing the lever at the rear of the restraint and lifting the seat up.Place the base in the vehicle facing the rear. Thread the vehicle shoulder andlap belts through openings at the end of the base without twisting the belts.Secure the belts by placing plastic tongue over the belts. Tighten the vehiclebelts by pushing down on the base and pulling out any slack.Step 3Install locking clip to secure shoulder and lapbelt together just above the seat belt buckle. Connect the two belts with thelocking clip. Buckle the lap belt system and tighten by pulling out any slack.Ensure that car seat base is secure by pulling and pushing on it; the baseshould not move sideways, forward or backward.Step 4
Place the Graco carrier in the base. Push down onthe restraint until it clicks and locks into the base. Set the infant in therestraint for travel and place harness straps over the baby's shoulders. Clickthe chest place together over the sternum and lock the buckles into placebetween the legs.Tipsand Warnings
  • Contact local police departments, hospitals and fire departments to inquire about child car seat safety checks
  • Graco Infant Restraint/Carrier will not protect against serious injury or death if not installed properly. Always read the Graco owner's manual that comes with product prior to attempting installation and travel with an infant.
Jul 19, 2011 | Home
Reebok Challenger 150 Treadmill with SpaceSaver Technology - Built-in Logo
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
