Question about Stihl Garden
How to fix recoil on Stihl BG 55
Replaced cord, started once used turned off tried to start again, rope pulled out won't recoil / start? how to fix
5 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: stihl bg 55 blower runs good for 5 min. then loses power
1) carburetor gaskets/diaphragms may need to be replaced
2) ignition coil may be breaking down when hot
3) check compression when cold, then after it stops, when hot
4) could have a vacuum/pressure leak
*I would investigate carb first
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
  • 394 Answers
SOURCE: I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Posted on Feb 26, 2010
H2_Brad
  • 425 Answers
SOURCE: HOW TO FIX BROKEN ROPE IN PULL START FOR STIHL BG 61 AV LEAF BLOWER?
The pulley the rope goes onto needs to be fully wound against the spring. I usually wind the pulley and hold it with one hand while feeding in the new rope with the other. The pulley may have a cut out on it where you can hook the rope and then wind the pulley. Once the pulley is fully wound by the spring you can hold the end of the extended rope/grip and let it slowly wind back into the recoil assembly.
Posted on Aug 24, 2012
  • 76 Answers
SOURCE: TB4BP won't pull
crankcase could be full of fuel causing it to hydro lock take plug out and see if it will pull over be carefull though if it's hydro locked with fuel it will pump out of the sparkplug hole. the rope may be off of the starting pully as well
Posted on Aug 30, 2012
Stihl BG 55 Blower Starter Rope Won't Pull.
indications are that there is insufficient oil in the mix and the ring has failed and jammed
you may have to pull it right down or simply junk it
if it has been discontinued then parts may also be scarce
Sep 24, 2016 | Stihl Bg 55
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
Trying to recoil a spring on start rope on a FS 55
No but you have to be very careful not to let spring go. curve on spring should match up with molded curve on the housing.
Oct 02, 2013 | Garden
Poulan lawn mower cord won't retract
New or used unit? If new can you return it ? If not you will need to take the recoil assembly off the engine and rewind the spring. Check inside the recoil assembly to see if the spring is broken or just popped out of place on either end. If it is broken your done. You will need to find a Poulan dealer to get a new spring. If new take it to a Poulan dealer for warrenty replacement. If you want to try to rewind the spring look to see where one end of the spring fits into the housing and the other into the spool. On the edge of the puley should be a notch. Place the rope in the notch and turn the pulley it in the direction needed to wind the spring about 4 or 5 turns. If it now pulls all the rope in you are done.If not put the rope back in the notch and wind the spring tighter till the rope is all pulled in.
Jul 25, 2013 | Garden
How to remove the circlip/orange pin from carrier to replace pull cordThe pull cord snapped. Trying to replace it but there is a circlip around an orange pin(?) in the centre of the housing/carrier. Using...
most the time you can repair the rope without taking any of that out.. but if it was me in your position i would return to the store you purchased it from and they can repair it under warranty.
Aug 24, 2012 | Stihl Trimmer Recoil Carrier Driver Km 45...
Aug 22, 2012 | Garden
Replace pull cord
i roadworks63. Pull off the right side cover to expose the recoil, remove the rest of the rope. Now rewindthe pully c.c.wise until it stops then release it just enoughto align the rope holes,use a C clamp to hold the pully from unwinding. Insert the rope enough to tie a knotHeat the knot to make it hard,now slowly let the pully re..turn or unwind tieon the handle. You are home free.
May 17, 2010 | Stihl Concrete Cutoff Saw Rewind Recoil...
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Pull cord broke
if you have not replaced cord you will need to do this,when you fit the cord turn the pulley 4 or 5 times full circle the same way as if it was pulling cord,then feed cord through pulley and out of housing to fit handle when this is done you can let pulley recoil and you should have correct tension,hope this helps
Mar 10, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
393 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
